Question about Polaroid FLM-3734B 37 in. LCD HDTV
37" Polaroid LCD TV No signal appears when select channel
All channels are programmed in, working fine one day, next try turn it on and blue screen appears with 'no signal', some channels the picture appears for afew seconds and then goes to blue screen with 'no signal', when you select PIP little boxes appear with visual of the channels so we know it not a tuning of channels/aerial problem. Can you help it driving us nuts!!!
  • 5 more comments
  • keystoneC Mar 10, 2008
    SAME ISSUE - 32" Polaroid HD widescreen LCD TV/DVD combo: was working fine for months now the blue screen appears with 'no signal', some channels the picture appears for afew seconds and then goes to blue screen with 'no signal'.  I checked the connection and get great channels on other tvs to the same connection.  Checked input, reset settings, changed cables, etc.  Please help!
  • BW502 May 06, 2008
    I have the same problem. I managed to get rid of the blue screen by going to Menu > Options > Blue Screen > Off. Now I can actually see all the channels, although the "No Signal" bubble appears over the top of the picture after a second or so. However, I don't have any sound. Also, the tuning doesn't seem to 'hold' - ie if I turn the TV off and back on again, the picture on all channels is jumpy, as if the TV was not correctly tuned. Auto programme fixes this, but then the TV returns to its silent "No Signal" state.
  • pincheturi May 28, 2008
    screen suddenly turns blue with "NO SIGNAL" in right corner, I've reset channels, checked cable connections, it works fine for a couple of hours then starts again when it does I turn tv off wait for red light then turn back on and it works for half hour or so, this is ridiculous, HELP ME!
  • Anonymous May 30, 2008
    bluesceen, no singal, pitcher poping when it comes in and snow, huming when truned on
  • Anonymous Oct 31, 2008
    i have had similar problems ,i reset the digital channels now i get nothing apart from a blue screen,thought i was getting a bargain,now i just have a head ache,nothing in the instruction manual says what to do once i have reset to factory settings,looks like i will have to use my freeview box .unless anyone can help.thanks
  • Anonymous Dec 31, 2008
    First channels were programmed into the tv, after a while you couldn't get no channels but no signal with blue screen
  • Anonymous Mar 30, 2014
    channels 105-115 I get the description box on the screen but no picture
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Posted on Dec 03, 2008
How do i set up pip
Posted on Nov 29, 2008
My Polaroid 32" HDTV just recently acted up: it has loss it's HD channels (ie 2.1, 2.2, etc) all of a sudden. The TV is set to "Air" as supposed to "Cable" setting even though it is connected to cable that only has two cable channel. It was fine before and had set the TV several time to rescan for channels and it was perfectly fine. I tried several times to scan and even resetted to its several manufacture setting and had no luck what so ever. I know for the fact that if when it scans for channels it only receives those channels that are most clear and strong, while it leaves out those that may have weak signals. I never had problems recovering those HD channels but now I have all analogs insteads. It's driving me insane because I hate the fact that these locals channels have HD and I only get their standard analog signals. I know that this is not the best brand of TV out there and it worked. My TV is feeding off cable with limited cable broadcast and should still work even though it is set on "Air" as supposed to cable.
Please let me know if anyone of you have encountered the same problem(s), and if you solve the mystery. Would some please tell me what does "PIP" on the remote means and what and how to use it. Thanks in advance.
-Ethan (soltero415@gmail.com)
PS I woudn't be able to return this TV back, the store that I bought this just filed Chapter 11. :(
Posted on Nov 13, 2008
So, I couldn't get the tuner to work (tried everything). Eventually I realised the cheapest solution would be to buy a digital set top box, and use this as the tuner instead of relying on the one built-in to the TV. Works fine.
But yes, I won't be buying another Panasonic in a hurry.
Posted on May 24, 2008
  • 3 Answers
Don't ever buy a Polaroid television again, manually reset factory settings via Menu button. You must do this each time you turn on the television when it was off.
Posted on May 22, 2008
37" Polaroid HD LCD black display but appears to be "on"
The power supply board was having problems before.That the board,where the power a/c cord plug into it Now might also the Tuner board are dead too.The tv Tuner board,that the board where the tv broscast signal cable plug into it.That the Tuner board.Tries Websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement to see if solved the problem,not probally will have to buy the refurbish Tuner board for the replacement too.
Jul 13, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Will NOT acknowledge one channel
This problem was already posted by someone else and they were having the same issue as you.. they said that they contacted FOX engineers via email and they emailed them back stating there was a problem on there end and with in the next day the channel started to show up on the Olevia television.
Seems like FOX has changed there frequencies and some television were having trouble picking them up.. depending in the area..you might want to try contacting them in regards to your problem to see what they suggest..
Jul 10, 2009 | Olevia LT27HVX 27 in. LCD Television
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
My remote control for my polaroid tv wont change channels up and down.the channel button isnt working for the tv.everything else is working.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Apr 19, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
There is no sound on only one channel
go into the menue, hit setup, hit program chanels, or auto program, and let it program again, if that chanel still has no sound, then it is in the signal and not the tv, the tv cand single out 1 chanel and mess it up, the tv dont know the diferance between one channel or the next
Jan 10, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Dec 09, 2008 | LG 37LC7D 37 in. LCD HDTV
Polaroid FLM-3734B 37 in. LCD HDTV Logo
5,404 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
