Question about Hand Tools
I have a rubber coupling between the motor and the bits shaft that is worn away and would like to replace it I do not have a part # the model is 40457
  • 122 Answers
Go to ereplacementparts.com
Posted on Feb 06, 2010
Testimonial: "I contacted the link you sent they will send me a email within the next 2-3 days (kind of slow)"
Whistling
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
Jul 22, 2014 | Whirlpool Washing Machines
Rumble on spin
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Feb 27, 2014 | Frigidaire ATF6000ES Front Load Washer
During spin cycle loud clunking noise
Feb 16, 2014 | Frigidaire GLTF1670A Front Load Washer
Replace bearing and outer tub
Feb 13, 2014 | Frigidaire Washing Machines
Spinning cycle sounds rough
Feb 12, 2014 | Frigidaire ATF6000ES Front Load Washer
I was advice to change the long shaft coupling some time ago. I realised there is some vibration when doing 90km. recently I was advice to change another coupling along the long shaft, which makes it...
Things that go wrong on this propshaft:
Centre bearing. A bearing mounted in a rubber housing in the centre of the vehicle. Inspect the rubber for cracking and tearing. Replace if worn. The bearing itself rarely wears out before the rubber mount.
Universal joints - there are 3, one at the differential in the rear of the car, one at the center bearing and one at the transmission in the front of the car. When worn you will hear a distinct metal "clunk" when taking up drive on pull-away. Check by gripping the shaft either side of the joint and twisting eah side in opposite directions. There should be absolutely no play in the joint. Replace if worn.
Whenever a joint is replaced it is nescesary to have the shaft balanced again.
Sep 09, 2010 | 1997 Isuzu Trooper
Burnt rubber smell after replacing motor coupling
what has happened is that the coupler has not been fully seated on the gearbox shaft, the motor shaft, or both. you should use a socket and hammer to firmly seat the plastic coupling on each shaft. If the coupling is not properly seated, the washer will work, you will get rotation, but there will be constant back pressure on the motor shaft, pushing it against the rear bearing race and the pump at the rear, the added friction causes heat buildup in the motor and sometimes overtemp switch operation. Just solved this tricky problem myself. another clue that the coupler isn't fully flush and seated is the last motor retention strap is very difficult to get on, due to the 1/8-1/4 inch extra length.
Jan 16, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a model 110.81375130 Kenmore washer that is making a grinding noise during wash cycle. I already replaced the agitator shoes (similar to agitator dogs on other models). The bottom agitator is only...
A grinding noise from a washer more often than not means that your motor coupling is worn or broken. The coupling is a small plastic and rubber piece between the motor and the transmission. Not too difficult to replace yourself and very inexpensive. If it is the coupling you may see bits of rubber beneath the machine. If you look up underneath the machine it will be obvious of the coupling is your issue. If not I would recommend calling a licensed repairman to check it out.
Dec 12, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer does not spin even though water fill and drain properly. Water level presure swith working properly. How do you cehck the capacitor and the motor to make there is power get to each part. Washer is a...
OK,
This could be something not related to the electronics. The motor has a coupling that connects the output shaft to the transmission. If you can, check below the washing machine using a flashlight. If there is black rubber dust below the machine, that bushing needs to be replaced. It is worn out...The part is about $20 to $25 depending on where you purchase it.
To replace the coupling, drain the washer, then unplug the power. Tilt it back, then remove the motor to inspect the coupling. You can easily replace the coupling by removing the motor. There are two metal retainers that can easily be snapped loose using a large screwdriver. Pull the motor away from the transmission housing, then remove the existing coupling and install the new coupling.
Once it is in place, clip the motor back in place, tilt the washing machine back down, plug it back in, and VOILA! You are in business!
Jul 27, 2009 | GE Washing Machines
Whirlpool toploader gearbox/clutch removal
Last Night I took the machine apart to find clutch/brake assy ok gearbox was also ok then I noticed shaft coupling was different than new part I had in stock, new part made totally of nylon, old part fitted to machine has steel insert built into nylon. this was not fully located onto motor shaft and the first 1/4" of motor shaft had been stripped back to round ( no flat faces) also inside the steel lined bore of the nylon coupling had been worn to round.I replaced with new coupling of nylon and ensured both nylon parts fully pushed home onto motor shaft and gearbox shaft with any freeplay / gap being allowed in the rubber drive link. This has worked for now but expect trouble in future with worn motor shaft.
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Hand Tools Logo
41 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Bill Boyd
Dan Apthorp
Are you a Hand Tool Expert? Answer questions, earn points and help others
