Question about Whirlpool Washing Machines
Will not spin, motor just 'hums' fills, washes and pumps just fine. Just no spin
  • mrbeltjr Feb 06, 2010
    whirlpool LSQ9110PW0 Will mot spin,
    fills, pumps and washes just fine. No spin
    Habit-Forming:
  • 84 Answers
You have to post what kind of washing machine you have
Posted on Feb 06, 2010
  • Sergio Vicente Feb 06, 2010
    it sounds like your clutch pads are worn,they sell a kit for it about $60.00 it will solve the problem
Washing machine fills and agitates but won't spin or drain, just hums.
When the machine beeps it is giving you a code with the 8 wash progress lights along the top. Some will be on some will be off. With OFF = Zero and On = 1 Can you give me the 8 digit code. An example is (01001001) It is normal for the pump motor to get very very warm. Make sure you can spin the pump impeller easily.
Aug 09, 2014 | Fisher Paykel EcoSmart GWL15
Why does my kenmore washer 110 fill with water but won't wash or spin?
Do you happen to hear a humming noise coming from the machine after the tub fills? This might indicate that the motor is spinning, but the belt that connects the motor to the rest of the machine works is broken. It is located underneath the washer. Tip the washer a bit and have a look. If it's broken, you'll probably find the belt laying on the floor. Take that to an appliance parts store where they can match it up with a new one. Installation is not too difficult. The belt will go around the motor pulley, the transmission pulley, the water pump, and in some cases, a spring-loaded tensioner. I hope this helps! :) -Jason
May 06, 2014 | Kenmore 22422 Top Load Washer
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
Washer will fill with water and then pops the circuit breaker
see the causes:
t doesn't pump or spin
frozen puller+ belt broken replace
It pumps, but doesn't spin
lid swithc broker or open,motor coupler broken,belt broken, and clutch worn,drive motor defective,transmision not shifting properly,basket driven worn.
It spins only with the lid closed lid switch prevent the action to start.
see the diagram
Jun 19, 2012 | Washing Machines
Washer fills up but the will not wash
sounds like something is clogged in your pump under the washer.
see the motor drives the pump, but if it is clogged, the motor will not turn.
Sep 12, 2009 | Kenmore 24032\24036 Top Load Washer
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Pump Replacement for Washer??
yes it is the pump motor, if you say when you close the door, it clicks but can you hear the motor humming, this is a sign the motor is seized up and the power is actually going to the motor, or test with and electric tester,, it is the pump motor I started typing before reading the whole statement,, good luck
May 30, 2009 | KitchenAid KAWS850L Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Year old frigidare washer won't agitate
the selector switch might be out.
Aug 08, 2007 | Frigidaire FWTR445R
Washing Machines Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
