Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ice machine not making ice, green light is blinking but don't see any stuck ice cubes
    Sergeant:
    Champion:
  • 263 Answers
A blinking green light on the ice maker indicates, that it needs to be replaced.
Ge profile refrigerator repair in orange county, ca
Posted on Feb 06, 2010
My PT Model IM-600 US ice maker makes cubes but continues to freeze on the ouside of the cube tray blo th cubes from falling into the bucketwhat is wrong.
cubes set too large
Adjusting the Ice Cube Size: 1. Press and hold the "Adjust" button for approximately 3 seconds until the Green Indicator starts blinking, release the button. The unit is now in Ice Adjustment mode. 2a. Press the "CLEAN" button to decrease ice cube size. The Red Indicator will flash as you lower in size and will blink when you have reached the smallest possible setting. 2b. Press the "MODE" button to increase ice cube size. The Yellow Indicator will flash as you increase the size and will blink when you reached the largest possible setting. After 10 seconds without any operation, the unit will return to the previous mode. NOTE: • During the ice adjustment mode, if the "ICE FULL", "ICE MAKING" and "ICE HARVEST" LED's all blink simultaneously, this means setting is at the regular (middle) size. • When the machine is in the cleaning stage or ice full stage, the ice size cannot be adjusted.
Dec 04, 2017 | Refrigerators
Refrigeration light blinks green
make sure your fan and compressor is running or your condenser and evaporator is not dirty
Sep 17, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My GE GSL25JFPEBS side by side refrigerator stopped making ice. The green power light blinks indicating ice being stuck, but once the ice is removed from the mould, the problem starts all over again. It...
i am wondering if ice is constantly getting stuck or are the cubes smaller that the size of the mold? if that is the case have you tried replacing the water filter. The typically reason ice gets stuck in the mold is because the individual cubes (usually 7 or 8 per mold) are too small,the leading cause of that is not enough water in the mold
Also is water dispensing through the door with good pressure, if no replace filter but first check the pressure of the incoming water from house plumbing
Jul 29, 2011 | GE Refrigerators
Refrigerator has stopped making ice and the light is blinking above the ice maker switch. what do i need to do to correct this problem?
My book says that ice cubes may be stuck in the ince maker.
Turn off the icemaker, remove the cubes and turn the icemaker gake on.
Feb 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
ZIS480DRISS NO MAKING ICE CUBES
FINGERS THAT EJECT THE CUBES WAS JAMMED ON WHITE PLASTIC. REMOVED ICE MAKER THAWED CUBES IN THE TREY AND PRYED AWAY THE WHITE PLASTIC COVER. RE-INSTALLED
Jan 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stuck
Switch the ice maker off then back on should reset it . It is possible that the 'ice mould heater' is not working so the ice cubes don't realease from the mould , jamming the motor. Replacement ice maker is usually the solution
Aug 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
General electic gsh25jfta bb
According to the manual for your refrigerator:
Blinking green light indicates an ice cube is stuck in the icemaker. To fix - Turn off the ice maker with the on/off switch. Then remove all of the ice from the icemaker by hand and turn it back on.
I hope this helps.
Jul 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSS25LGM Ice maker
one of the valves could be open circuit. ice build up where the pipe enters the cabinet or sadly if not that then the complete ice maker. hope this helps
Feb 11, 2008 | GE GSS25LGM Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
735 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
