Question about Garmin nuvi 350 GPS Receiver
I can't turn it on - GPS does not work.
I can't turn it on at all. Batery was low and stopped working once ran out out battery. After that, it stopped working. I tried to charge it, but nothing helps. It does not work from car charger also & reset botton does not help.
any suggestions?
thanks,
  • 4 more comments
  • galau Feb 21, 2008
    yes, i tried that too - nothing happens...
    i charged it all last night, bit i am not even sure if it is charging..
    when i connect to any charger, the screen is black and nothing indicates that the unit is charging - i tried USB / car / regular charger...
    that's what i also think - but the thing is that i just bought this unit - one week ago, brand new! very dissapointing...
    amazon.com - yes, i can and will return it. Thanks a lot for your help! Kind regards,
  • jennymay May 15, 2008
    it just will not work.i reset it and still nothing.please help i have a 330 garmin
  • kathyspig Oct 06, 2008
    GPS itemx3-08
How long are you charging the unit?
Posted on Feb 21, 2008
  • 504 Answers
Have you tried charging the unit from the computer? This can sometimes help.
  • 1 more comment
  • Kevin Miller Feb 21, 2008
    If you cannot tell if it is charging, it is NOT charging. When the unit is plugged into the computer, is should turn on. Then it should display an image of the unit connected to a computer with a cable. If it is not doing this, it is not charging. It sounds like your battery may be done for. You might need to contact Garmin about replacing it.
    Where did you purchase it? Can you return it and get a new one? If you can, this would be your best bet. It is a great GPS, but not if it doesn't come on. :)
    Any time. I wish I could have done more for you. Good luck with it. Any problems in the future, let me know. :)
Jeep liberty electrical
The battery is run down too low. When the light came on, alternator stopped working- the vehicle ran off the battery, until the lights and other electricals ran the battery down too low.
Recharge the battery, and have the alternator tested. It will probably need replacing. If you bring it into a parts store, they will test it for free.
Sep 19, 2013 | Cars & Trucks
At first i tryed updateing it and i used the wrong update .so i did a master reset. that dint work. the web updater would nor recanize the garmin 465T . so i used google to get the right updat then i got...
Find a local Garmin dealer - there's no way to reinstall system software once its missing essential parts to complete a startup.
Garmin allows updates in battery mode which can brick the GPS once it runs out of power during the update.
Mar 14, 2011 | Garmin Nuvi 465T Car GPS Receiver
My tomtom 920 simply won't turn on, I used it yesterday and it was fine, though it did warn me that the battery is very low. I have charged it for 1hr but it still won't come on. What could be the problem...
The batery is finished, even if you plug it in the cigar lighter and the green light goes on, your TOMTOM will still not work when the batery is dead..get one real cheap on ebay.
Good luck
Apr 21, 2010 | Tomtom GO 920 GPS Receiver
I have a ford explorer ltd 95 and yesterday when
Easy way to check. Crank the vehicle while running remove one of the battery cables from the battery if the ingine dies your alternator is bad. I'll bet it is the alternator.
Oct 24, 2009 | 1997 Ford Explorer AWD
Low battery, won't charge
connect the garmin to your computer using the usb port. It will start charging then. For some reason when the battery goes dead in this unit the only way to charge it is with computer. the car adaptor will not work once the battery gets real low.
Apr 16, 2009 | Garmin StreetPilot c340 GPS Receiver
Turn off garmin
I just find it unbelievable that there is no off button on this watch. I dont want to use it as an everyday watch..its too big and ugly for that.Also you have to remember to turn off the gps as it will drain the watch overnight.You have to switch the gps on every time you do a run. I simple on and off button is all that is needed.It is just a matter of turning it on when you go for a run and you are ready to go. Same with all 'latest ' products..they give you the improvement over the last model but give you a downside...which will probably be corrected on the next incarnation....very clever marketing.!
Feb 03, 2009 | Garmin Forerunner 405 Handheld GPS...
How and where do I replace a fuse on A tom tom one car power cord
Ther is a small batery looks like large watch battery or computer battery inside unit.
sumtimes thay are soldiderd in place.
you should change it with new one.
this will fix your problem.
Jan 10, 2009 | Tomtom ONE GPS Receiver
My garmin 340 suddenly stopped working
Ummmmm "Low battery"....... not too hard to figure out. You need to charge it for several hours. If the battery is low it WILL go out on you and during that time, the battery may recover enough to come on briefly then go off again. Please charge your battery!
- Jim
Sep 13, 2008 | GPS
Nuvi 205 voice stopped working
I had the same problem. I went onto Garmin.com and attached the Nuvi to the computer using a cord that I had for my blackberry phone. Once connected, I turned on the Nuvi and ran the update tool. The update tool will reinstall the voices. This seemed to work the first time. I have had to do this twice now since I received the Nuvi 205 on December 26, 2008 (it's February 13, 2009)
Aug 09, 2008 | Garmin Edge 205 GPS Receiver
Laoptop batery
Try taking the battery out for 30 secs or so and then replacing it. You'll find a couple of locks on the bottom of the laptop that will release it.
Jul 10, 2007 | Toshiba Satellite A105-S4004 Notebook
Garmin nuvi 350 GPS Receiver Logo
85 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
