Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
I set my Windows XP PC to have a static IP address on our wireless lan because our Apple OSX laptop wasn't finding it. Apple found it but lost it again a day later, and it can't seem to find it when I do the "connect to server" thing in Finder. What to try next?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
Create a profile in your Network Settings and put the static IP address and save it.Restart the system and try.Hopefull the issue will get resolved.If not please reply me.
Posted on Apr 12, 2010
Cant set up static ip address on windows 7
Yes you canGo to Start> in the search box type ncpa.cpl > right click wireless LAN click properties > look for internet protocol v4 highlight it then click properties > select use the following IP address.
Mar 14, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Hi, I have D-link AirPlus Xtreme G Wireless Router. The problem is that when i connect my laptop to the wireless connection it says it's connected but then i cant even open a page. I'm with...
The problem could be that the static IP address is not in the range as the IP address as the router.
You should let the wireless router issue an IP address to your computer.
Change the TCP/IP settings in your laptop's wireless card to Obtain an IP address automatically and Obtain DNS server address automatically.
Then reboot your laptop.
May 22, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router requires resetting with MAC PC
My first suspicion is that you may be experiencing an ip address conflict. If your iPhone or PC is using the same IP address as your iMac, only one of them will be able to communicate (and possibly neither of them). This should occur only if one or more of these devices are using statically assigned IP addresses. Check the internet configurations for your devices and make sure they are all set to use dynamic (DHCP) addresses.
For reference, a manual for your product can be found online at P-660HW Series - Ultra High-Speed Wireless ADSL 2+ Gateway for ...
There are several models and versions of your product, and the manuals are different for each, so knowing the exact model and version of your unit would help in diagnosing this problem.
May 16, 2010 | Zyxel P660HW-D1 Router
Can't figure out how to connect my printer to the "network"... hope I'm using the right terms. Had it all set up to a dlink wireless router with a modem and had to disconnect it all to resolve another...
connect a lan wire from router to printer
print printer information
find out ip
pls add static ip address on the pc(printer and pc should be in one network)
type ip address on the internet explorer
change the ip address of your router class ip network range
remove static ip from pc
Oct 28, 2009 | Brother HL-2170W Mono Laser Printer
How to Change DWL-G710 IP address
in your case, you only need to change the range expander's IP address from 192.168.0.30 to 192.168.1.30
to do this, you need to connect a computer's LAN cable directly to the range expander's LAN port. when both devices are powered ON, then access the initial IP address http://192.168.0.30
when you are in the web interface, click the LAN button and enter the suggested ip under the IP text box: 192.168.1.30 see figure below.
when you already set the IP, click on APPLY. then you are good to go. You can then connect the router, then connect the range expander to one of the router's port, then computers.
Oct 22, 2009 | D-Link AirPlus G Wireless Range Extender...
D-link DIR 300 wereless connection workng, but LAN will not work
Sounds like you have a static IP address on your PC which is preventing you from connecting to the router. This normally happens when you change the router for the origional that was provided by the ISP. Easy to fix. Just set your IP address back to dyamic & you will contect over LAN just fine. If you want to reconfigure your static I.P then I would be glad to help but that is another question.
Just revert to dyanamic IP address & all will be well.
Jul 03, 2009 | Computers & Internet
One of five PCs not connecting to Belkin 54G router
I would connect it to the router using a lan cable to verify that it will get a IP address and connect to the internet. Write down the IP information and make a static wireless connection with that info. It should work hardwired and wirelessly with this info. If it doesn't work wirelessly you may have a bad wireless card or you may find that their is already conflicting static IP info in the connection that has to be removed. Make sure that on your internet protocol (TCP/IP) properties that you have selected "Obtain an IP address automatically" and Obtain DNS server address automatically". Clear any settings that you may see there.
Jun 22, 2009 | Toshiba Satellite Pro 6100 Notebook
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Manually assigned IP setting lost
see there are two types of connection in your laptop pls see u define on which network choose local lan and assign ip adress and save .
Dec 17, 2007 | Computers & Internet
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
52 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
