Platten not moving when keys and space bar struck. There is a cord @ back connected to a spool now broken and unconnected which appears to be the only thing not working
  • 61 Answers
Possibly the brawband for the carriage has broken but you can replace it with some nylon cord.
First wind up the spool for about four turns before connecting the cord to the underside of the carriage at right end.
Posted on Apr 24, 2010
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
Can not pull cord all the out to start the saw
Sounds like the pull cord has become trapped round the spool. Remove starter housing and unwind the pull cord manually off the spool. Then wind the cord back on by hand. Be careful because the spool will be under tension from the rewind spring.
Mar 18, 2013 | Husqvarna 240 Chainsaw 16" Bar -free...
The space bar has come off how do i fix it
Often with keyboard keys, they have several clips that hold the keyin place. Try gently prying the key off again, and see if there is any placewhere the plastic might have broken, or if there were other clips thatweren't quite in place. If the key is broken, though, you can either deal with it as it is, orprobably order a new key.
Jan 07, 2010 | Sony VAIO PCG-K23 Notebook
Underwood no. 5 typewriter doesn't advance when hit keys
the cord is shaped much like a shoe lace, and these make great replacements, a spare clip can be fashioned out of a paper clip, it's not a precision part. the spring if broken can be replaced with any clock style spring, i bought a wind up kitchen timer at the dollar store (same for the shoe lace) and took the spring from that. for $2.14, got mine working good as new
Nov 01, 2009 | Office Equipment & Supplies
I have an old school "Royal Quiet Deluxe" typewriter; the carriage will not move when the letter keys are pressed or when the space bar is pressed but will move to back space or to slide the carriage back...
If there is tension on the carriage when you push it to the right, the spring is not broke or the cord..then the problem would be in the escapement area..you would need a repairman to do this. if the carriage is loose, no tension then the spring is either broke or the cord is off or broke.
Either way not something easy....
Sep 29, 2009 | Royal Office Equipment & Supplies
Broken recoil start on tecumseh 6.5 hp
broken cord? remove bolts holding recoil housing.lift housing straight up,you may have to wiggle it a bit.turn housing over,remove any cord thats left,note how & where it connects to the spool.wind the spool [and consquently the spring under it]in the direction the cord would turn it as pulled when starting.hold spool tight.thread new cord through hole in housing.let spool turn back just enough to attach new cord.hold cord & housing,let spring "re-coil" cord slowly.check for smooth operation.replace housing.you may need to pull cord slightly to align 'square' shaft w/hole in spool.only after you are satisfied with the operation of it adjust length of cord by pushing excess cord through the handle,tie a new knot,then cut off excess,if any.
Sep 21, 2009 | Garden
Olivetti Lettera 22 - Ribbon Spool doesn't advance.
these are tricky to repair, I would suggest taking it to a repair shop (check the yellow pages) check repair directory on this site, sorry , no easy answer on this one
Jan 03, 2009 | Olivetti Lettera 25 Typewriter
Correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it
9) Replace the cassette ribbon and close the top cover
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Jul 16, 2008 | Brother GX-6750 Typewriter
Space bar sticking on Saitek lighted keyboard
For me, I popped of the space bar, cleaned the junk underneath and fidgeted with the plastic push-button and all was better. Thanks for the suggestion!
Feb 21, 2008 | Saitek Eclipse II
jasbo
jasbo
