Question about EliteGroup 661FX-M Motherboard
Can not install windows xp
Sir,
Kindly help me solve this problem, I can't install os windows xp on my sata hard disk
  • 2 more comments
  • charlito arrocena Feb 21, 2008
    Sir,
    Please give me hints or solution to solve this kind of problem. Am I to change my hard disk?
    Thank you'
    Hubag
    Thanks
  • Anonymous Apr 16, 2009
    can't install widows XP on SATA hard Drive in MSI 661FM-V
    error message is can't find any hard drive in your system
    when I use SATA Driver floppy disk and perss F6 Key and windows instaaler begin install driver an error message code displayed (1024) error
  • junior franco May 11, 2010
    WHAT IS THE PROBLEM?
    President:
  • 2,351 Answers
Hubag, you need to check your bios. At boot up, press the delete key every 2 seconds & your bios will load. Make sure your SATA drive, (s) are listed example: {if your SATA drive is a Seagate the bios will show it as: ST3250823AS}. You should unplug any IDE hard drives connected to the system while installing Win XP. The Southbridge integrates a Serial ATA host controller that is SATA v1.0 compliant, supporting Ultra DMA 150 (SiS964 only). If you do not have your manual you can download it here at:
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=392&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
661FX-M(V1.0B)
Once the bios is set & see's your SATA drive so will windows.
If you can not set your bios to list your SATA drive windows will never install on your SATA drive. You can also use the above link & down load drivers, including a RAID driver.
Posted on Feb 21, 2008
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | HP Computers & Internet
Can not install os, computer says no hard disk installed
This laptop has a SATA hard drive.
Feb 23, 2012 | Panasonic Toughbook CF-30 Notebook
I have using vista os with my pavilion dv6000 entertainmen laptop
Hi there.
What you want is the intel matrix storage manager for theextra drivers so XP install can see the SATA drive. Download it fromhere and please make sure you read the read me text on how to set it up
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2101&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
Good luck and thanks for using FixYa!!
Apr 09, 2009 | HP Computers & Internet
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
Installatin problem xp
do you still have the other hard disk? Is xp installed there?
Then you can use the old disk as master and the new disk as slave disk.
Don't you have another hard drive? Then you just need your xp cd and put it in your cd drive. start computer and installation will automatically start. Make sure BIOS is set to boot from cd
if you need more help, just reply
Apr 04, 2008 | Computers & Internet
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
Installation problem for windowxp
You may not have enough space on your hard-drive/s.
Nov 17, 2007 | Microsoft Windows XP Professional With...
How to burn a bootable xp cd with sata drivers slipstreamed into it
I have never used this utility but Bootdisk.com has a solid reputation, for $4 US get access to his special utilities.
FResh XP install With SATA ---- SATA1 fresh install of XP using WIN98 and SATA drivers Seems like it will install XP with SATA drivers and then you can see your hard drive.
Nov 08, 2007 | Microsoft Windows XP Home Edition
EliteGroup 661FX-M Motherboard Logo
245 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
