Question about Lexmark T630 Laser Printer
THERE IS PAPER JAMMED IN THE LEXMARK T630 AND WE CAN'T GET IT OUT
    Problem Solver:
  • 12 Answers
First you take out toner cartridge and see if paper is jam in fussing unit otherwise open the back side door and take out fussing unit and clean the paper jam
Posted on Feb 06, 2010
Location felt swipper on lexmark t630
top rear of printer at teh back of the paper exit tray is a cover with the fuser wipe inside.
Jun 11, 2014 | Lexmark T630 Laser Printer
241 paper jam message
Lexmark T630 241 paper jam message - Indicates a paper jam from the pull down manual feed tray.
If you check to make sure and small fragments of paper are not hindering the operation of the switch. The switch is located on the left side of the tray and will be spring loaded. The switch should move freely without binding. Make sure no toner or dust is on the optical sensor assembly. See Diagram for location.
If the switch seems OK and the printer still reports an error, the printer will require professional care.
Jan 15, 2011 | Lexmark T630 Laser Printer
Lexmark t630 error says remove paper standard bin. Never knew anything about standard bin -- can't get it to print, and yes, there is a connection to the computer
The Remove Paper Standard Bin error can be possibly caused by the exit flag that is out of position, stuck or broken. Follow troubleshooting steps found at http://bit.ly/dhOTEo. If any part of the flag or holder appears to be broken, contact Lexmark technical support or a local authorized service provider.
Sep 20, 2010 | Lexmark T630 Laser Printer
Hello i have a lexmark t630 and when it prints out of tray 2 it says change tray two and beeps. It will work normal if you hit the select button. What could it be?
the printer is telling you that the tray is reporting the wrong size paper. print the network menu from tray 2 if it prints out smaller than the page it will be reporting smaller than letter. if the bottom line of the outline is missing its reporting legal size paper. if you are running lettersize paper in the tray check on the left side of the tray half way down the drawer you will see a plastic snap in plate with 3 fingers the bottom 2 should be sticking out for letter size paper. you only have to be one of the small adjust teeth off to make the third finger stick out and report the wrong size paper this is a very common issue. look at the metal fingers that stick out of the frame of the options tray to make sure they are uniform and straight. if the fingers are set right and not damaged then the logic board in the tray assembly will have to be replaced
May 14, 2010 | Lexmark T630 Laser Printer
Lexmark T630 Error message "Paper Jam Remove rear cover." No paper jam...
Open the rear, there is one of the paper sensor actuators stuck. They are spring loaded and should spring back when pushed out by the paper.
Oct 14, 2009 | Lexmark T630 Laser Printer
Lexmark T630 error message: Change MP Feeder
use the right arrow go to paper menu scroll to the right to paper source select if it is set to mp tray reset it to tray one. if its set to tray 1. check the side of the paper drawer to make sure the paper size snap in plate is in place. if these things are good replace the paper size selection pcb located in behind the logic pack
Sep 15, 2009 | Lexmark T630 Laser Printer
Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Dec 31, 2008 | Lexmark T630 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark T630
I would suggest pulling the toner out and paper tray and using compressed air to blow out all ereas of the printer. If that does not work then you will have to remove the 2 screws at the back of the printer and with the two tabs at the top remove the backa nd look for paper jammed inside.
Feb 27, 2008 | Lexmark T630 Laser Printer
Lexmark T630 Laser Printer Logo
243 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
