Question about Xerox WorkCentre PE120 All-In-One Laser Printer
Printer reads document jam uses a minilla folder to try and clear jam still reads same think how can I get to doument sensor to see if its the sensor
    President:
  • 2,072 Answers
Most likely the sensor has come out of its mounting.
Most likely just carefully disassemble the the feeder and find the loose sensor, Remove the back and left side cover, follow the wires to the circuit board, Unplug them then lift the feeder up and out of the machine. Place it on a table and you will get to it, It really is not a hard feeder to take apart and put back together.
Posted on Feb 05, 2010
When i printing douments on internet that time print not get properly
I Think thats not the issue of Printer.. if it is ready while printing form MS word,excel etc...
So Please Copy the Document Contents from net and copy it in word or any other software. Then print it! ....
Dec 29, 2010 | Epson LQ 300+ Matrix Printer
Paper jam with my photosmart c4280 printer- help!!
Try this link...It may help.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00860153&product=3192753
As for the cartridge jam try resetting the printer. Open it up, make sure there is not jam. Move the carriage over if necessary, hit OK. Then turn the printer off. Go to your computer and remove any documents from the print queue. Then, with the computer still plugged into the printer, turn the printer on.
Mar 11, 2010 | HP Computers & Internet
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Document jam
There is most likely a very small piece of paper in the document feeder.
What you can do is take a minella folder or some card stock, open the document feeder cover and shove the folder or card stock through the feeder to dislodge whatever is stuck in there.
The document sensor itself may be knocked out of position.
It can't be the copy paper path since you can print.
May 16, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
Document jam
There is a sensor in the document feeder that most likely is stuck on the frame or the spring fell off and is not resetting. Have you taken a minela folder and run it through the feeder to be sure there is not a small fragmant of paper on the sensors? If you havent try that, or a piece of paper folded in half twice and keep sliding it though the feeder.
You would have to take the feeder apart to get the sensor set, That is best accomplished by taking the back cover off, then the left side cover, ( looking from the front) and disconnecting the feedder connectors, then removing it from the scanner.
Apr 07, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
ADF Document Jammed
Have you tried manually rotating the ADF wheel back and forth, sometimes the sensors are OK but the rotators lose grip.
Oct 23, 2007 | Brother MFC-8440 All-In-One Laser Printer
Paper kam that wont clear
Canon Pixma IP5000 kept giving the blinking yellow light 3 times. Could not find anything. I tried the manila folder forcing a manila folder in on power up through the top feeder as suggested for another Canon Pixma. The folder kind of jammed and pushed it back out of the feeder. And out came a small piece of postit. Couldn't see it so it was somewhere inaccessible and unviewable. The bigger paper was enough to loosen and expel it with the manila folder. I'm guessing the people who put the higher mil (thicker) paper through, clear what ever is causing the problem even if they don't see what is ejected or forced out. Don't know if this will work for you but it thats what happened and the printer works fine now.
Dec 24, 2006 | Canon PIXMA iP5000 InkJet Photo Printer
Xerox WorkCentre  PE120 All-In-One Laser Printer Logo
56 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
