Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
My washer is washing and rinsing, but it will not spin. My washer is a kenmore 22642100. What can I try to fix it?
  • 572 Answers
Check your lid switch. for a top loader
Posted on Feb 05, 2010
How do i fix washing machine
Reset level selector by turning to low and back up to desired
Try hot and try cold. See if either one will fill/partial fill.
Try rinse
Try spin only.
No rinse no spin Check timer electrical
If spin but no water hot/cold look for defective level sensor.
Dec 07, 2015 | Kenmore 24032\24036 Top Load Washer
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Have a 110.22642100 Kenmore washing macihne that has a metal clang on the spin cycle that occurs every second or less. The tub does not rotate much. I replaced the motor coupling since it was split but is...
Hello Jye,
It does sound like either the clutch is bad or the Motor coupler is bad. I have included a video showing how to replace the coupler Kenmore Washing Machine Model 110 22642100 11022642100 110 22642100 Parts
The coupler is about $18 and the Clutch is about $48
Good Luck!
Rich Lilja
May 19, 2017 | Kenmore 22642 Top Load Washer
I have a Kenmore stackable washer/dryer (apartment size) and the washer will shut off when it goes into the spin or rinse cycle. If I turn the control knob to rinse or spin, nothing happens. The washer...
try looking at your pump or you need a cupler that goes on the back sid of the motor price range for the pump is 120 dollars and the cupler is 35 dollars dont quote me on the price of the parts please but that should fix the problem.
Jan 31, 2010 | Kenmore Washing Machines
Washer will not rinse and spin.
mine did the same thing...its something that i couldnt fix but the repairman said it was the drive assembly kinda like the transmission for ur car , it still agitated but wouldnt spin...it needs to be replaced
Jun 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore Elite
Luckdan209
your washer is not agitating -
1. Check that water level switch works
2. Does it attempt to move when selected? Washer timer contacts may be burnt.
3. Your motor could be bad - washing spinning different ckts
Regards
Sep 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
279 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
