Question about Belkin (F5D5231-4) Router
We have just tried to set up a belkin N wireless router and the modem red light stays flashing. Therefore , we have not been able to connect with the wireless
    Guru:
  • 194 Answers
If you follow these steps it should clear up your issue.
  1. Unplug power from your modem, router and computer (turn off computer). Check to make sure your modem does not have a back up battery in it.
  2. Plug the coax (cable) or phone line (dsl) into your modem
  3. Plug an ethernet cable from your modem to the router. Make sure it is plugged into the "internet" port.
  4. Turn the modem on and wait 40 seconds for the lights to come on and the system to boot up fully.
  5. When it is up, plug the power into the router. Wait another 40 seconds to a minute for all the lights to come on and be green.
If this does not help please let me know and we can move further with your support. Routers can sometimes be very sensitive.
Good Luck,
NOLA Tech
Posted on Feb 05, 2010
Wireless light flashes & can't connect
Are You Sure You Have Signal coming into modem/router sometimes the red light indicates no connection is it dsl or cable or? if DSL can you use the phone disconnect the filter. and plug the cord strait into the wall plug.cable could be the connection check for shorts could be an issue with your carrier call them for a simple electronic reset Hope this helps!
Jul 26, 2017 | Belkin Components F6D4230-4 Wireless...
Amber light flashing on belkin 150 router
Disconnect the ISP modem power and network / cable. Do the same with the router. Wait a few minutes and reconnect starting with modem.
Oct 08, 2012 | Belkin Connect N150 Wireless Router...
I cannot access the router settings.The light keeps flashing green.I cannot manually set up my settings.It said the setup was a success, but later when I was setting the router settings it told me I lost...
Flashing green means its trying to contact the modem. So, there is some problem with modem-router connection or with the modem.
Disconnect the modem from the router and connect the modem alonely to the desktop and check.
If you are unable to go online, restart the modem/reset the modem.
After that, connect the modem to the router, then reset the router (In the back side, U can see a reset button. Hold the button upto 10-15 seconds, lights will go off and it will vary). then, power off the router and after 10 sec, make it on.
Then it will go to default settings. Now, try to go online.
If not, Call Belkin 1800 2BELKIN. Life time Free phone support 24*7.
Nov 30, 2010 | Belkin Connect N150 Wireless Router...
For some reason the light above the WPS button keeps flashing red. I have tried multiple reboots, none of which have worked. when connected to the ethernet modem, the light stays as a solid red color.
You need to reset your Router before setup manually.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 16, 2010 | Belkin Wireless Play Router (F7D4302)
So I got this Belkin router (N) and the wireless light just comes on and goes off as it feels what up?
Idea of Belkin router is blinking orange is simple but there can be many more reason behind that light code .
It just can be ISP issue (may be internet service provider is down )
you might want to restart the modem than router and wait for like 1 min this Belkin router blinking orange to green.
For more details kindly visit
Belkin router blinking orange FIX belkin router amber light Issue
Good luck.........
Feb 27, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Belkin Router problem
A red light on your belkin router means its already busted as you decribe other lights are not ON at all. In all other types of modems and routers Red LED light on it mean synching up and if more than 20 secs with a red light is already considered busted.
Note: You may also check your phone cable rj11 , power surges, defective phone jack.
Jun 15, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin f5d7633-4 wireless g modem/router
when you upgraded did any settings from your isp change like passwords or usenames that your router may not be registering at your isp's server, or the line speed that you are now getting is not suported by the router.
type 192.168.2.1 in your web browser and check the connection settings.
Oct 20, 2007 | Belkin (F5D7633UK4A) Wireless Router
Belkin (F5D5231-4) Router Logo
146 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
