Question about Brother MFC 420CN All-In-One InkJet Printer
Need to reset memory
I have a brother MFC-420cn and I am having a difficult time sending faxes because it says the machine is out of memory. How can I reset the memory?
  • 2 more comments
  • Anonymous Feb 22, 2008
    eweo
  • Anonymous Aug 18, 2008
    says out of memory...cannot fax!!!
  • Anonymous Aug 21, 2008
    need to fax but dont know how to. seems to not work.
  • jilljann Apr 30, 2009
    can not send fax, "NG: poor line condition/out of memory", what do I do?
How do i reset mfc 420cn printer?
Posted on Nov 24, 2008
Need to reset memory ?
Posted on Feb 22, 2008
On 6-4-2012 could send fax, now 6-07-2012 can't send or recievsed fax
Please check the settings on the fax machine. check the line to the fax and also the connectors, check using a phone to hear the dial tone.
If this seems good check if the fax dials the call, if not check the settings for pulse or tone and reset. If there is not dialling then the fax machine has problems that are serious which might need careful probing.
Jun 06, 2012 | Brother MFC 420CN All-In-One InkJet...
Can't fax multible pages
Your fax machine reads multiple pages into memory before sending the job, this is the pool memory. Two things can cause this error.
  1. Corrupted memory, which keeps the job from transmitting because the data stored is scrambled and lost prior to transmission.
  2. Line static, which makes the connection so unstable and slow that the fax can't get enough pages out of the queue fast enough to make room for the next pages entering the buffer.
If you checked the line and it tested good (not just listening for a dial tone), then it is probably a memory issue.
May 06, 2010 | Brother MFC 420CN All-In-One InkJet...
Cannot send Fax messages on Brother 420 due to full memory.
Perhaps you can try this:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000095/faq000195_006.html?reg=us&c=ca&lang=en&prod=mfc420cn_us&Cat=11
Nov 27, 2009 | Brother MFC 420CN All-In-One InkJet...
How to fax (face up or face down)
If you put the document on the glass surface, your document should be face down. If instead you use the automatic feed on top of the machine you should place your document face up and the top of the page inside he feeder.
Hope it helps.
Aug 28, 2009 | Brother MFC 420CN All-In-One InkJet...
Cant recieve fax
please help me how to switch my machine Brother MFC440cn to fax/tel mode.
Oct 26, 2008 | Brother MFC 420CN All-In-One InkJet...
Problem with my fax Machine MFC 420CN
You can cancel a fax job that is stored and waiting in the memory.
1 For MFC-210C,
press Menu/Set, 2, 5.
For MFC-420CN,
press Menu/Set, 2, 6.
Any jobs that are waiting will appear on the LCD.
2 If you have more than one job waiting, press ▲ or ▼ to select the
job you want to cancel.
Press Menu/Set.
—OR—
If you only have one job waiting, go to Step 3.
3 Press 1 to cancel.
To cancel another job go to Step 2.
—OR—
Press 2 to exit without canceling.
4 Press Stop/Exit.
That should do it for clearing faxes you dont need you can also print off all the faxes in the memory and I believe that clears it.
Enjoy,
Lee
Jun 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Erase memory from fax
unplug the unit and take any battery's out. then plug back in
Mar 17, 2008 | Brother MFC 420CN All-In-One InkJet...
Fax memory
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000100/000095/faq000195_006.html?reg=us&c=mx&lang=es&prod=mfc420cn_us&Cat=11&ot=us_ot
Nov 15, 2007 | Brother MFC 420CN All-In-One InkJet...
Receiving faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
1,364 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
