Televison & Video Logo
Anonymous Posted on Feb 05, 2010
Screen extremly dark with pixles migrating in black areas.
  • 4 more comments
  • Anonymous Feb 05, 2010
    LG plasma tv model # 50pc3d-ud serial # 602rmen120332
  • Anonymous Feb 09, 2010
    I have a LG 50pc3d-ud which is a 50 inch plasma tv.The screen is extremly dark and black pixilation in a migrating pattern.Have replaced capcitors that were bad on main power board can you tell me which board to replace or were my problem might be.It is with all inputs and no other problems with sound powering on ect.Turn brightness and contrast all the way up and is still one third as bright as should be.Were do i look which board should be replaced,even main menu dark.
    It is a LG plasma tv 50pc3d-ud.I have replaced some bad capacitors on main power board.Can you tell me which board needs replaced or point me in the right direction?The screen is very dark maybe one third as bright as it should be with brightness turned all the way up.It is not signal,all inputs come out the same .Screen is very dark with migrating pixilation.Could it be underpowered more capacitors or anouther board. Thanks
  • Anonymous Feb 12, 2010
    No apprent damage on zsus or ysus but did replace 3 bad capacitors on main power board.
    The migrating pixilation is dark spotts screen extremly dark with black spots that migrate around depending on picture in all different areas sizes ect.
    Thank you for an answer to bad the problem is extreme.
Anonymous
Level 3:
  • Master 5,138 Answers
  • Posted on Feb 09, 2010
Anonymous
Master
Level 3:
Answers
5138
Questions
5
Helped
1003612
Points
13534
What is your Make and Model number ? It will be printed on back of set.
    LG Techs ay that this is a mjor problem and that you need to replace all 4 PCBs in order to correct this problem.
Anonymous
Level 3:
  • Master 4,889 Answers
Anonymous
Master
Level 3:
Answers
4889
Questions
8
Helped
1512231
Points
14106
Migrating Pixels means, you have intermittent bright spots on the screen? If yes I am afraid it is an issue with the display panel. However lets confirm before we come to a conclusion. Did you check the Y-Sus and Z-sus board for any apparent damages?
A
Anonymous
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Very dark screen in full screen mode
Check the monitors native resolution (you can get it in their website's technical specification area and set the same resolution in your windows resolution.
I have an LG Flat Panel 37LG 50-UG.ACCOLJM. The picture has many vertical lines less than a CM apart and the colour is wrong and looks negative (light is dark and dark is light)
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them,. Good luck in solving the problem and do take care because it contains high voltages.
My hp C7180 all in one printer told me I needed to replace an ink cartridge as it would not print in color. I replace the one it said, still did not work, I have replaced all the cartidges and it is still...
First perform an observation of the printers compartibilty to color printing. For example, the printer ought to have been manufactured to capture color pixles to provide resource request in multimedia. usually is possible to have one printer that has several ink location areas to either install color media or dark ink media. In situations where a printer was designed to be black and white ink document compartible would least produce results on color when ink was interchaged. Ascertain that the printer is compartible with multimedia pixel printing proir to acquirng depeltable resources from retail.
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
2answers
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
2answers
Screen does not lighy
If you look very closely, is there an extremely dark picture, or a solid black screen? If it's an extremely dark picture, you just need a new backlight. If it's a black screen, you either have a bad connection (broken, shorted or unplugged cable), or need a new LCD. Let me know, and we'll go from there.
3answers
Dell a940
Check that you are not printing in draft mode, before looking into www.fixyourownprinter.com
Acer AL1715s
Hi, Maybe it is a stuck pixel try this link perhaps this will give ya some insight ... But it sounds as if ya monitor is going flakey :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
