Question about McCulloch Garden
I have two mcclloch timber bear chain saws 3.4 and I'm looking for two throttlelinkage rodsthe one from the carb. to the trigger
    President:
  • 2,220 Answers
I found a 13-600041-34 Timber Bear IPL here:
http://www.ordertree.com/modelinfo/MCC/13-600041-34-TIMBER-BEAR-07%2F90-to-Current-IPL-211627/139.13-600041-34-TIMBER-BEAR-07%2F90-to-Current-IPL-211627.1.59.1.html
On the "General Assembly" Illustration, item 71, is a "Rod, Throttle". An Internet search for McCulloch 214504 returns many sites showing this part in stock.
I make no claim this is your saw or this is the part you seek. I defer to you to ensure applicability.
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
There are also
13-60041-35 and -36 (often part of serial number). I saw no other prefixes used with 600041. Again I am human and do err.
In a pinch a piece of hobby store piano wire and a couple pair of pliers can probably be used to fabricate what you need.
If you have additional questions you can reply below and I will help further, HTH
Lou
Posted on Feb 06, 2010
  • dontbother10
    dontbother10 Feb 06, 2010
    Suffixes are usually part of the model number not serial. The prefix is usually associated with the serial number. I told you I was human. LOL
    Lou
    ~13-600041-35 and~ Phat Phingers too.
    You meant what I knew.
Need a new Talon Chainsaw sprocket for 35cc 35cm Timber Hawk AC3100-35C
most chain saw chain sprockets are either 1/4 or 3/8" pitch
in your case I would suspect it is 3/8 pitch
measure the distance between the link pins ( not the teeth but the pivot pins of the chain itself )
after that the sprocket will be available as a generic sprocket from any chain saw shop or mower shop
Talons went bust but are being reproduced under a new brand name ( ozito I think)
Jun 28, 2016 | Talon 219 Kart Sprocket 62 Tooth
The engine starts fine, but why doesn't it rev when I press the trigger?
Have you checked the throttle linkage to the carb.?
Apr 21, 2016 | McCulloch Garden
Saw wont idle, runs wide open
Some saws have a throttle lock that locks the trigger to aid starting. Get a look at the carb to see if it opens when the trigger is pressed and closes when the trigger is released. If it stays open the lock may not be releasing or the throttle linkage is bound up or disconnected from the carb.
Dec 13, 2013 | John Deere 28 30 40v 50v 55v 60v 70v 80ev...
I replaced fuel and carb lines on my Poulan 2450 chain saw. I cannot seem to find the correct path/attachment for the throttle connection. Parts diagrams do not show this. Can someone provide a diagram...
It is quite difficult to explain exactly how it fits, the cable always looks too long and has to curl around on itself back to the trigger, the picture shows quite well how it goes, the end of the cable with a dog leg in it goes to the carb, as far as i remember it goes to the upper hole in the carb spindle, just push it into the hole and turn through 90%, the other end fits into the throttle trigger.adw1_9.jpg
Sep 10, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Cannot keep chain tight
Chain stretch is usually caused by inadiquate oil/ or incorrect oil to the chain, aim the tip of the bar at a clean peice of timber, you should see a good line of oil spray from the tip of the bar onto the timber.
Very dirty or dusty timber will also dry the oil out on the chain, and cause chain stretch.
Feb 24, 2011 | Husqvarna Chain Saw 20" Bar
I am looking for a manual for Timber Tuff chain saw sharpener model cs-bwm>How to 'true 'the cutting disc, and tips on how to use the sharpener.
Go to Gemplers.com, look up Timber Tuff electric chain saw sharpener, click on it, go to Online Documents tab and you can print off the manual!
Nov 01, 2009 | Electric Chainsaw Sharpener
I am having a problem with the oiler,getting oil to the bar&chain.
pump is probably gunked up! pour a dab of oil on it between cuts if you really have a task you need to finish up! then crack the case to the saw open and take a looksee
May 26, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Need true chain/bar size for my husqvarna Model 254 chainsaw
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Feb 25, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
243 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
