Question about OKI MICROLINE 3321 Matrix Printer
Oki 3321 set up for printing, when i'm trying to print it gives error
  • 40 Answers
SOURCE: printer is going over each line twice
check your driver make sure the driver is the same on both printer and in windows .If you are using IBM make sure you use " IBM Proprinter" in windows.Hope this helps.
Dezzi
Posted on Nov 29, 2008
Buschchris1
  • 474 Answers
SOURCE: OKI B4600 Printer will not print = error - paused
Does it have a control panel or buttons on the printer itself?
If so, are any of them blinking or red?
Sometimes an error will cause a pause in the printer and you have to press one of the buttons to get it to start back up again.
http://my.okidata.com/PP-B4600-Black.nsf?opendatabase
This is the link to the manuf. website. I did a search on your model, theres a few so i guessed. but the manuals are available along with drivers.
I suggest you go and update them and go through the PDF and see if there is anything partaining to this issue.
I went through the PDF a bit and didnt see anything partaining to the PAUSE issue but try going through and see if anything is it.
On the printer icon on the bottom right of your task bar, right click on the printer icon and see if you can select CANCEL print job, then try unpausing it. Also, power off and then power back on and see if that clears it.
You may have to un-install the printer and re-install it and update the drivers to clear it.
Sometimes a Print job will get stuck in que when theres a jam or something and it wont continue till the issue is resolved, then you open and close the top cover and that resets it, it rechecks then continues.
Good luck.
Posted on Feb 04, 2009
SOURCE: How do I set OKI B4600 to print to top tray?
On the back tray where the paper comes out just push the extra piece in that helps to catch the paper until it clicks and it will automatically start coming out the top so you pages are in the order that you want them to be.
Posted on Oct 07, 2009
Testimonial: "The one and only answer!!!!"
SOURCE: OKI C5650n USB port not working
Yes, well I can´t help you to solve that problem and in fact i´m hoping that you´ve already solven it, cuz right now i got the same problem with my c3450... It worked just fine under vista x64 but now on windows 7 x64 i have the same problem as you have/had!
Cheers
Posted on Nov 08, 2009
  • 97 Answers
SOURCE: have a oki c9800 ...gives error 923
923: Error - Black Image Drum Lock Error
The K ID unit is not operating
properly.
Check to confirm that Image Drum is seated properly.
Check to confirm that the K ID
unit is in position.
Replace the K ID unit.
Replace the K ID motor.
Posted on Mar 29, 2010
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
How to get rid of error light
check if all sensors work freely
and print head moves freely from side to side
Jun 12, 2013 | OKI MICROLINE 3321 Matrix Printer
Hi,, i have an oki MC160n,, that has an error coming up after a couple of pages being printed.. it says "paper size error, reset paper (1lt) press start key" can you help me fix this please
Please check the settings in your printer that you have selected correct paper type and tray from which you are printing. Also while giving print command make sure paper size is same.
May 05, 2011 | OKI Office Equipment & Supplies
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
HI Guys I want to configure MS word to print on OKI ML 3321
Go to Start->Printers and Faxes or Start->Control Panel->Printer and faxes.
Then right click on your OKI printer and click Set as Default Printer.
Word will now print to this printer.
Regards,
nicolasiac
Feb 10, 2010 | OKI MICROLINE 3321 Matrix Printer
073 fatal error in OKI c3530
Oki ERROR 073 is a H/W Overrun detect. this occurs when the video circuit has set the overrun bit. Restart the printer and check the first print out. Try printing a different job and then reprint the same job that the error occurred. If you get the same error again, try using a different driver, ie swap from PS or PCL whichever you were using to see if that clears the error.
Dec 28, 2009 | OKI C3530N Color MFP Printer
Cheers
Jun 02, 2009 | OKI Office Equipment & Supplies
Printer is going over each line twice
Dezzi
Jun 26, 2008 | OKI MICROLINE 3321 Matrix Printer
Double Printing
check the printer drvier properties and make sur the defaulf is not set to print 2 copies.
Jun 14, 2007 | OKI MICROLINE 520 Matrix Printer
OKI MICROLINE 3321 Matrix Printer Logo
228 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
