Question about Polaroid FLM-3232 Television
Polaroid film-3232 lcd television
Could I get the PCB lay out of the boards in side of my tv. I need to trace down this problem. I have opened it up yet, so it could very well be a flat cable loose? cracked board? Or could it be as easy of a configure change on th O/S?
well let me tell you what it is doing.
thank you
Joe
Just reseat the video cable (flat cable)that goes from the control box to the lcd panel.
Good luck
Posted on Mar 31, 2008
My polaroid model 3232 lcd tv has picture but no sound
Manuel, there is a 10 ohms resister, location r385 open on main board.
Oct 29, 2011 | Polaroid FLM-3232 Television
Tip
Polaroid FLM-3232 Service Manual Download
Download Polaroid FLM-3232 LCD HDTV Service Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLM-3232 LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3232 LCD HDTV Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Polaroid FLM-3232 Manual Download
on May 01, 2010 | Polaroid FLM-3232 Television
Tip
Download Polaroid FLM-3232 LCD HDTV Manual
Have you misplaced your Polaroid FLM-3232 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3232 LCD HDTV Users Guide?
Follow this link
I hope that helps.
_____________________________________________
Are the Polaroid FLM-3232 and the Element FLX-3202
not sure if there the same but the boards inside may be.
This sounds like the problem most LCD tv's get with swelled up capacitors in the power supply board. look for circular cylinder shaped parts rapped in plastic with writting on the sides, and metal tops, if the top is rounded over, not flat, it is bad. replace them.
Jul 22, 2009 | Polaroid FLM-3232 Television
Universal remote code for a Polaroid LCD TV
I may be able to help with your Universal remote and your Polaroid LCD HDTV.
You can find some Polaroid HDTV Remote Codes here.
I hope that helps.
Feb 26, 2009 | Polaroid FLM-3232 Television
I need a universal remote code for a Polaroid LCD TV FLA-3232B
I may be able to help with your Tevion Universal remote and your Polaroid LCD HDTV.
I hope that helps.
Feb 26, 2009 | Philips 32PFL7332D 32 in. LCD HDTV
Polaroid FLM-3232 LCD Television
Sounds like a crack in the lcd panel or a toren or seperated ribbon cable on the lcd panel,could also be a bad memory board but not likely,dropping the remote could not cause this problem unless the remote hit the tv when it was dropped
Mar 08, 2008 | Polaroid FLM-3232 Television
Polaroid 32 lcd hdtv/monitor model flm-3232
yes you have to test voltage but you must plug it in and check the power supply board first, the most common problem for those things is the 24 volt transformer in the power board fails check it for 24 volt output first, then trace the power route from there and the component that the board traces lead you to that dont transfer power through it will most likely be the problem but start at your power suopply and work outward from there. mine the 24 volt converter or transformer blew. i have been looking for one for 4 months. there is a eeprom in the main video board that blows also its easily found, it turns the unit on from the standby switch. check it also with a volt meter. you cant miss it on the board.
Feb 20, 2008 | Polaroid FLM-3232 Television
Polaroid FLM-3232 Television Logo
44 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
