Question about Microsoft Windows Vista Ultimate Edition
IBM Via vioce Pro dosn't work on my vista run computer..
    Guru:
  • 194 Answers
After installing the program, right click on the icon and select properties, hit the compatibility tab and run the program in windows xp compatibility. You can also visit the website and see if the program is supported in Vista. There may be an update to make it work.
Good Luck,
NOLA Tech
Posted on Feb 05, 2010
Does't work anymore
I would call the phone company back, if what you say was caused by them..
May 24, 2013 | IBM USB Portable Diskette Drive (05K9276)...
How to run windows 7 with ah3450 grafic card on kod p4x266 motherboard?
The MSI PM8m-V Motherboard has the Via P4M800 and Via VT8237 chipsets.
The website for MSI Does not list any drivers for Windows 7 for your motherboard. But since this is a common Via chipset you should be in luck.
A lot of driver support for VIA chips is built into Microsoft® Windows® 7 (32- and 64-bit).
VIA Hyperion Pro drivers
The VIA Hyperion Pro drivers contain all of the main platform drivers for VIA chipsets. The current release of these drivers is included in Windows 7, so at this time there is no need for a VIA Hyperion Pro package that supports Windows 7. However, as updates occur, a package will be released when needed.
You shouldn't need them, but to download the VIA Hyperion PRO Drivers click on the following link:
http://www.viaarena.com/Driver/VIA_HyperionPro_V524A.zip
The drivers for your video card the ASUS AH3450/HTP/256M Radeon HD 3450 AGP Card can be found here:
http://www.asus.com/Graphics_Cards/AGP_A_series/AH3450DI512MD2LP/#download
If you still need further drivers for this motherboard you can go to here:
http://www.via.com.tw/en/support/drivers.jsp
If you still have not found the drivers you need you can go to the MSI website and see if any of the Vista drivers will work for your system.
http://us.msi.com/product/mb/PM8M-V.html#/?div=Driver&os=Vista%2064
Aug 03, 2011 | MSI PM8M-V Motherboard
Hi! Please help? I have a desktop IBM ThinkCentre 1) I formatted my harddrive in another computer, using via Windows Disk Management option. 2) Replaced the HDD, and wanted to run new Windows XP...
download the Spotmau PowerSuite to solve he problem go for this link http://www.tech-pro.net/howto-fix-ntldr-is-missing.html do step by step .try it afer some time i will give another solution.
Nov 12, 2010 | IBM ThinkCentre A50p PC Desktop
I am running two 15 spl soundstream woofers with a soundstream 500sx amp how do I bridge them to get maximum performance
the 15 spl woofers are dual voice coil, i believe 2 ohms per voice coil.
the 500sx amp is rated 4 ohms bridged at 500 watts, it is capible of dropping to 2 ohms sterao, but no lower than 4 ohms bridged. to get maximum performance, you cannot use both voice coils of both speakers, you can only use one speaker, or both speakers, while only using one voice coil from each.
there is no point of bridging them, you can achieve maximum performance by attaching one voice coil from each speaker to each channel of the amp, while leaving one voice coil from each speaker unconnected. you could also use just one speaker, attaching one vioce coil to one channel, and the other vioce coil to the other channel. then, i would suggest getting a second, identical amp to run the second speaker.
if you are persistent on bridging to mono, then you can only use 2 voice coils (both from one speaker, or one from each speaker) and you must run the voice coils in series, that is, from the amp positive to the 1st vioce coil positive, then run a jumper wire form the 1st vioce coil negative to the 2nd vioce coil positive, then, finally, run the 2nd vioce coil negative back to the negative of the amp.
this is all assumming that each voice coil is 2 ohms and each vioce coil has seperate inputs, meaning that each speaker has 2 pairs of speaker terminals.
Oct 08, 2009 | Soundstream SPL 15 Car Subwoofer
Intellistation Dreaded "ntldr not found"
You have the solution given the fact that the IBM netloader wants to be subordinant to a loaded OS on a different drive acting as server when used on a thin client like the Intellistation. Unless carried as a portion of the registry of an MS OS, XP or Vista will drop it unless registered with a NetUpdate as a standing part of the registry. But most sysops conduct updates without all clients active so that some will inevitably be dropped, which is why the best strategy is to conduct updates on Off Hours when all clients can be up without human interaction, impossible during the workday, unless you deactivate an entire set of nodes for the purpose.
Run a reregistry while the Intellistation is on and active but without an operator and your problem should disappear more permanently.
Apr 21, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Sound card Problem
sir
i am umesh my computer not work in a audio vioce so tell me what can i do
Aug 22, 2008 | Microsoft Windows Vista Ultimate Edition
Fax modem 56k 2.9 audio dosn`t work when connect to internt with win vista
well if ur using vista u need to check if da modem ur trying to install is vista compatible or not if not den just let me know ur modem name + model number so i'll find ur modem driver if ur modem manufacturer released their vista drivers if not then buy a vista compatible or vista certified modem or simple solution is that go back to windows xp coz its a fine window n u can wait for windows vista for some 1/2 years so that vista have some problems n errors which in computer language is called bugz so let microsoft team to fix that bugz n may be ur modem manufacturer might releases ur modem driver too!
peace!
Oct 16, 2007 | Intel Motherboard
Microsoft Windows Vista Ultimate Edition Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
