Question about Tomtom GO 730 Car GPS Receiver
When driving sometimes the system goes out - Tomtom GO 730 Car GPS Receiver
  • yadayada
    yadayada May 11, 2010
    what EXACTLY deos it do?
  • 457 Answers
Check the power connector on the bottom of the device. After some time of use the socket does not provide firm seating any more and the Go switches off to preserve battery power (switch off in 10 seconds message). The auto-power off on connection loss can be deactivated, but since battery capacity is extremely poor anyway, it will soon emergency power-off.
I put the power cord over the arm of the mount in a loop (behind the device), so the weight of the cable does not pull out the plug so easily. An alternative car mount is available that has a design similar to the docking stand for PC connectivity. Here, the device rests on the plug and provides better connectivity by its own weight.
Posted on Feb 06, 2010
Not a heat problem, battery is full. Sometimes get as far as putting in password before screen goes black and shortly after, powers off. Even during a system test it goes off. please advise
Does this happen when the AC adapter is in use? It could be the hard drive not loading in the operating system or the coin cell battery has become depleted .
Jan 18, 2016 | Computers & Internet
Truck when it gets hot or after driving about 15 miles it will star to cut out or miss. Sometimes you can shut it off and start back up and it will run fine
I would start by checking your ignition system, mainly the ignition coil. Sometimes when they get hot they fail and when they cool down they work properly. I would also check to see if the fuel pump may be overheating as well. Connect a fuel pressure guage to the system and watch the fuel pressure after you drive it. When it starts to act up if the fuel pressure goes wild you will have your answer.
Apr 07, 2010 | 1988 Dodge Dakota
It comes on and a yellow light flashes and then it goes back off
Take the hard drive out of the system and then put it back in. Sometimes the yellow light comes on because the hard drive becomes unseated.
Try turning on the system and if the yellow light comes on, try another hard drive in the PS3.
If the yellow light still comes on then you know that the main board in the ps3 is bad.
Dec 02, 2009 | Sony Playstation 3 (PS3) Console
This is about my xbox 360 when i turn it on with the hard drive in it goes to a black screen and says system error in several different languages and a red light come on on the counsel and when i take out...
E68 error? If so, turn off system, take off hard drive, put hard drive back on (good and tight) and turn system back on. Repeat a few times, sometimes it takes me 3 or 4 tries.
Sep 28, 2009 | Microsoft Xbox 360 Console
XP won't load onto hard drive.
Start the computer and press the f8 key as if to start in sage mode, but select the "Disable system reboot on error" (not sure of the exact wording on that). Then when the BSOD hits it will stay there so you can get the error number and message.
Alot of times these are memory errors so I would also suggest that you download a program called memtest 86. It is a small ISO file that will create a bootable cd to test the memory. You can get it from:
http://www.memtest86.com/download.html
Hope this helps
Apr 20, 2009 | HP Pavilion dv8235nr Notebook
Sandisk cruzer micro code 10 error
This can be due to a internal problem,,,also can be avirus
The light should be in solid state i it's working right...and blinking only when a transaction is happening
Please don't forget to rate me "FIXYA"...thank you!
Mar 19, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
ABS/CHECK ADVTRAC/SKIDDING CAR LIGHTS GO ON
The abs sensors also control the traction control and 4 wheel drive actuators so if one of the sensors is faulty the traction control will be disabled and the drive system will be stuck in the mode set at time of failure be that 4x4 or 2wd
get the abs system repaired
Jul 25, 2017 | 2002 Ford Explorer
Power on
This sounds like it could be a faulty laptop battery. I would suggest plugging the system into AC power and then remove the laptop battery from the system. If the system boots then the issue is with the battery. If the laptop still does not boot, next thing to check would be to make sure that the hard drive is seated completely in the drive bay. Sometimes the hard drives can work themselves loose from moving around. By opening the drive cover and pulling the drive out and then reseating back into its slot can sometimes resolve the issue as well.
Aug 25, 2008 | Toshiba Satelite 5205-S505 Notebook
Laptop sounds alarm 30 seconds when turned on
your system has got Viruses. Better you Re-install the OS after formatting your Hard Drive. Your problem will be solved.
Feb 04, 2008 | Acer Aspire 5050-3242 Notebook
Tomtom GO 730 Car GPS Receiver Logo
90 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
