Question about Keurig Coffee Makers & Espresso Machines
Our Keurig Select B77 brewer turns itself off after less than a minute of being on. "Menu" is not appearing at bottom of display screen (can't check auto on/off function -- although we never did "set it"). We've only had it since Christmas (Dec.2009) and used it successfully almost a dozen times before this problem occurred. Help -- we like it, we want to use it.
  • 12 Answers
These brewers (B77, usually from Costco) are defective & Keurig is replacing them with new units @ no cost. Just call the toll free # (866-901-2739) & they will ship out a replacement in 3 to 10 business days. I own (2) of these & they have both been replaced.
Posted on Feb 15, 2010
They just replaced mine as well. I should be receiving my replacement machine in 3-7 days, and all I need to return is the k-cup holder from the machine. I also purchased mine at Costco, but my issue isn't the LCD display, but coffee grounds leaking EVERYWHERE. The replacement gasket they sent last week didn't solve the issue, so I'm receiving a NEW replacement machine free of charge. What wonderful customer service!
Posted on Mar 02, 2010
I had the same problem with my B77 from Costco. Thanks for the good advice - Keurig is shipping me a new one plus a couple of boxes of K-cups. In the meantime, I did get mine working again (temporarily) by removing the water tank and putting it back on while the machine was turned off, and when I turned it back on, it allowed me to go through the menu options and even more importantly, make a cup of coffee! I usually refill the water tank without removing it, using another receptacle. I wonder if this is what causes the problem.
Posted on Apr 12, 2010
I have a Keurig 2.0 when you plug it in the power button comes on, on the lcd screen but when you touch the power button nothing happens. It won't turn on. Any suggestions. Thank you.
Found the below from this site: http://coffeestylish.com/keurig-problems/
Keurig 2.0 won't turn on
To turn on your Keurig 2.0 plug in the brewer, then press and hold the power button (the power icon will appear in the bottom right corner of the touchscreen). You should see a welcome! note. If it doesn't turn on you can do few things:
Check to make sure that the brewer is plugged securely.
Unplug and plug in the brewer.
Plug the brewer into a different outlet.
As a last step, Keurig even recommends resetting your home's circuit breaker just in case.
If nothing works, then you should definitely call Keurig customer service.
Jan 24, 2016 | Computers & Internet
Why does the keurig menu button not work
www.keurig.com/.../brewer...support/frequently-asked-questions
Try here.
May 23, 2014 | Keurig B60 Coffee Maker
My Kerig brews a tiny bit and then stops. Can I use the vinegar solution on my B77 as is recommended for other B models?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 07, 2011 | Keurig B70 Coffee Maker
My Keurig B77 is not brewing,plenty water saying ready to brew but water is not going thru the Kcup. Can you help.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Mar 31, 2011 | Kitchen Ranges
Keurig platinum B70keeps shutting off
These brewers are defective & Keurig is replacing them with new units @ no cost. The pumps have a defective "check valve".
Just call the toll free # (866-901-2739) & they will ship out a replacement in 3 to 10 business days. I own (2) of the B77 models (lower option Costco unit) & they have both been replaced.
Feb 07, 2010 | Keurig Platinum B70 Coffee Maker
My brewer keeps tearing the top fo the k-cups. Is there a replacement to the orange foam cover?
Yes there is! This top needle seal is the revised part used for your brewer. Keurig did away with the orange seals. This part will fit yours...
http://iwantsweetdeals.com/Top-Needle-and-Seal-Replacement-B40-B50-B60-B66-B70-B77-P1227669.aspx
Jan 31, 2010 | Keurig B50 Coffee Maker
Coffee Makers & Espresso Machines Logo
1,474 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
