Question about Maytag Admiral Top-Freezer Refrigerator
I have an admiral refigerator (top freezer) less than 3 years old. The unit sat in a vacant house unplugged for about a year and now will not cool. Any suggestions
    President:
  • 1,218 Answers
Good day,
Check in the freezer compartment to see if you can hear the fan motor running. They will freeze up if left off for extended periods of time.
Another fan motor on the bottom back near the compressor can suffer the same fate.
If both check O.K. Then since it's under 5 years you could have a refrigerant leak or a compressor problem that is under factory warranty.
Call your selling dealer for service.
Posted on Feb 05, 2010
My top freezer is leaking onto the top of the refrigerator door. The fridge is 3 months old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Maytag Admiral Top-Freezer Refrigerator
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Freezer wont work after defrosted
Please keep in mind, I'm attempting to diagnose you appliance without being there and with very little info. Thanks
If the sound is a double click, then after about 2 or 5 Min's another double click. You have a bad capacitor.
If it's a low hum. It sounds to me like you have a low side leak in your freon sealed system. When you unplug the unit, the freon pressures equalize. This put higher pressure on the low side of the system than it has when it's running. If you have a low side leak, it will drain out under the higher pressure.
NOTICE
(Industury standard- 5 year warranty on all sealed systems) This means that if your unit is less than five years old and it is a sealed system problem. (Freon leak, Compressor) The factory will cover parts and labor. You should not need a receipt if it's less than 4 years old.
Sep 22, 2009 | Whirlpool ET4WSKXS Top Freezer...
Cold but not frozen
23 years old ? That thing was costing you more than a new unit would cost for the past 5 years!
Assuming your airflows are good, Its time for a new refrigerator.
Aug 29, 2009 | Refrigerators
My two year old admiral refigerator has air entering freezer part
lube the hinge side, sealing face of gaskets with vasoline. Heat gaskets with hair dryer then tape doors shut when hot. wait an hour before removing tape. do this on both doors.
Aug 26, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Fridege TBX18J MS not getting cold
hi is the fan motor going in the freezer. if so how long has it been plugged in if more than 24 hrs and the fan is going. it could be that because it sat for 10 years the lines that go inside could have rusted out. so if this is the case its scrap sorry. the appliance doc.
Oct 16, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Wont cool at all
on the compressor there is a device called a thermal overload its the box that plugs on the compressor it might be bad if you have a wire with two aligator clips on it you can jump the terminals on the thermostat as it may be bad if you do that and it starts then the thermostat is bad if this is a self defrost unit then find the defrost timer and turn it slowely clockwise if it starts then the timer is bad
Jun 02, 2008 | Coldtech 6 cu. ft. / 170 liter Commercial...
Admiral Refrigerator/Side by Side
compressor or sealed system issue compressor is failing or a problem in the sealed syetem is putting a back pressure onto the comperssor causing the compressor to eventualy kick of on the internal overload in the compressor, cools down as you unplug the unit allowing the compressor to cool down resets the internal overload runs and repeats the process
have the unit checed by a quilified tech in ref sealed system repair
May 27, 2008 | Admiral 26 cu. ft. Side-By-Side...
Maytag Admiral Top-Freezer Refrigerator Logo
110 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
