Question about HP LaserJet 2200D Printer
There are smudges all along one side of the paper, changed the toner and still the same thing
  • prosysltech May 11, 2010
    replace new fussing unit ,it will work properly
  • 1,219 Answers
Its fuser unit problem, replace fuser
Posted on Feb 06, 2010
  • 415 Answers
The drum is probably dirty. Try removing the toner and cleaning with a clean dry cloth. Don't use a damp cloth.
Posted on Feb 05, 2010
I have a Canon Imagerunner 1023if and have black smudges along the left edge of paper, both copies and printed directly from computer.
this is possibly a problem in the fuseing part of your machine, where the paper heats up at the back, the fuser roller could be worn out. and your toner could be sticking to it.
Sep 05, 2012 | Canon imageRUNNER 1023iF Black and White...
HP 1300 -- toner is smudged along the left edge after crinkly sound
Hi:
This is a common problem with some HP printers. The fuser sleeve inside the fuser assembly gets torn along the edge and print can no longer be fused in that area and the paper will crinkle there. The only solution would be to replace the fuser, which for that printer it would not be worth repairing.
Andrew
Jun 08, 2012 | HP LaserJet 1300 Printer
There is a smudged side on the fax when it comes across. I have changed the toner and shaken the toner up the smudge still comes back in the same place on the fax
If this smudge is showing up on the faxes you are RECEIVING and you have changed the toner then the next most likely cause is a fuser problem. This is especially true if the smudged area feels gritty or the toner rubs off the page in the smudged area. If this is the case then you need to replace the fusing unit or have a local repair place replace the fuser "film" on your fuser unit.
Good Luck and Thank You for using Fixya.
May 11, 2011 | Canon FAXPHONE L170 Plain Paper Laser
Toner smudges along left side of documents. Have changed cartridges and cleaned everywhere I could reach but they remain
It is likely your drum unit that is defective. Replacing this should stop the smudging. Be sure to buy a high quality replacement. Original Dell or reputable remanufactured only. Be aware of the vendor's return policy and failure rate before you buy.
Mar 18, 2010 | Dell Laser 1720 Printer
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Jan 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Toner smudges along the extreme right side of the paper
If the smudges are gradually fading then it's likely just excess toner hitting the fuse drum. Try a few cleaning cycles/test prints and see if that makes it go away. If not, see if you can get a replacement toner.
Jan 05, 2009 | Brother HL 5250DN Laser Printer
Smudges along the right side of the paper
Hi Scottmortona,
Welcome to FixYa!
I encountered this while printing my lecture notes for my students. This seems either a drum issue or the toner.
  1. Take out the toner.
  2. Ensure that the toner is evenly spread out by holding it horizontally, and tilt forward and backward.
  3. We need to ensure the toner is even.
  4. Take out the drum unit.
  5. Check are there any toner powder stuck on the sides of the drum?
  6. If so, use a soft brush and slowly brush off the toner stuck there.
  7. At the top of the drum, there is a blue notch. Slide this a few times to do a wire cleaning.
  8. Place the toner into the drum
  9. Place drum into printer now.
  10. Try printing a few pages.
Let us know if you have any problems.
Thank you for rating us.
Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Jul 08, 2008 | HP LaserJet 1320 Printer
Black smudges on copies
Hi, try to pull out complete process unit(cartridge) with toner box .You have cleaner(blue or green color) move this cleaner from right to left side 4 or 5 times.Note that cleaner MUST be in home position-right side when you finish.Check print.
If problem still persists, you must do following:take away small grey plastic cap on left side of cartridge,then push complete charge corona(part with cleaner on top of it) to left side just enough to lift right side of corona from cartridge.Pull out that corona and you can see drum and developer roller. Turn the gear on drum,and look for smudges on black developer roller.Try to clean smudges with brush or with dry cloth.Toner will again attract to that area,but regular.
Dec 11, 2007 | Kyocera Mita KM-1815 All-In-One Laser...
HP LaserJet 2200D Printer Logo
284 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
