Question about Philips Televison & Video
How to get all the cable channels on an older Philips TV that only seems to want to go up to 39
    Sergeant:
  • 231 Answers
You will probably need to get a cable box, or you might be able to send the signal through a cable ready DVD player to the TV.
Posted on Feb 05, 2010
42pf5321d/37 wont find cable channels
Check and replace its tuner. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 17, 2016 | Philips Televison & Video
Philips 26pfl5522d/05 TV Channel issue
Just been on Philips Forum and there is a possible very simple solution. Press and hold the MENU button ON THE TV for about 20 secs. This should factory reset TV and allow storage/retrieval of channels to the '8k' store. See this page for more detail:http://www.supportforum.philips.com/en/showthread.php?1366-26pfl5522d-05.
Now I have to ring my Dad who has exactly this problem!
Apr 03, 2012 | Philips Televison & Video
We have a Philips DVD3460 recorder. Where in the manual does it inform us on while Watching T.V. and DVD is recording another T.V. channel?. Would love to know " how to do this"?
It depends on your setup.
Think of the Philips DVD3460 as an independent, standalone television set. It has its own analogue tuner, and its own video input.
If you have an analogue RF TV signal (coaxial cable) going in to the Philips DVD3460, you can watch whatever you want on any other TV connected to the TV signal coaxial cable, since the regular analog TV cable carries all of the channels.
However, if you are using a cable or satellite box and use the "Video in" function of the DVD recorder or just have the DVD recorder tuned to channel 3 or 4 to record from a cable or satellite box, you can't record one channel and watch another unless you have a second cable box..
Apr 24, 2011 | Audio Players & Recorders
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
May 24, 2009 | Philips 26PF5320 26 in. LCD Television
Can only get channels 1-13,can't get the cable channels
Press Menu
Scroll right to TUN (Tuner)
Scroll down to TV/CABLE
Toggle from TV to Tuner
Problem Solved
Feb 15, 2009 | Philips Magnavox 27MS343S 27" TV
Red bar across top of screen??
I had the same horizontal, solid red bar along the top of the tv screen. I have an older analog Philips Magnavox TP2785C221. It just started all of a sudden. It was on every channel. However, the bar did not appear on the other input channels (e.g., AV1, AV2). So this meant that the red bar was only occurring on the antenna input. I unplugged my cable decoder box and restarted it. The red bar went away and that seemed to solve the problem for now.
Jun 25, 2008 | Philips Magnavox 42MF521D/37 Television
19 INCH OLDER MOEL
Hello.
You did not say if you were using cable or antenna. If cable, you need to use the remote that came with the TV. Get into the menu and look for channel setup or an equivalent heading. in one of your menu schemes will be a selection fot ant. or cable. Select cable and the other channels will magically apear when you exit the menu option.
Good luck.
Oct 17, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
