Denon DRA-95VR FM section loses stereo light, won't tune any station, no sound after playing 10 minutes. After awhile it comes back. Problem comes and goes at random. Amp section is fine.
  • 171 Answers
When you say no sound a mean not at all or you just have a noise sound, because if this is the matter the antenna should be the problem, you have to check the antenna connection and depend of your car Make/Model/Year the antenna input is at your factory amplifier, if this is not the case you have to disassemble the radio and check the connection at the back of the radio and make sure the antenna is tied and secured to it, if you recheck and see that the antenna connection is OK, them the problem is the radio and in this case you have to open the radio, check the circuits inside the radio to find out the problem but this is more complicated and needed for especial tools.
Good luck
Posted on Feb 05, 2010
When on FM tuner, stereo stops playing after a few minutes
Right then sounds like the connection from the aerial lead into the receiver - check out the socket where the aerial plugs into!
Is it loose at all or could there be a bad connection inside the unit.
Get the cover OFF and investigate yourself before you rush down to that very friendly repair man along the street.
Jan 05, 2014 | Denon DRA-365R Receiver
My Denon Audio precision am fm DRa 435R Reciever will not stay on station very long. After about 30 or sometimes 45 minutes it get off station. I have it set to a local FM Station, 97.9 and it plays good...
OK,this is a fairly common problem with digital tuners, I get them from time to time in my shop, you see, what is happening is the voltage that's used to tune the set, usual;y stays rock solid, your device however is drifting off station due to this voltage changing, usually it is in the powers supply or the actual tuner itself. It can be bad capacitors, bad IC's, bad transistors, bad tuner module. Sometimes it maybe a "Dry Joint" too.
The only fix is either a replacement PSU or Tuner or indeed maybe both? One simply cannot tell exactly without examining the unit.
You need to take this unit into a Denon repair center and ask for a "Quote" as to costings etc. Once appraised of that one can proceed from there?
Contact a Denon head or local office and ask them there, for a referral to an authorised service center.
Jul 18, 2011 | Audio Players & Recorders
DRA-345R stereo receiver. FM is gone, poof! just like that. nothing looks burned. where do I start? No change to the antennae has been made
I have a denon DRA-345R and when I put on position mode cd I can listen music and then after 1 minute the mode change automaticly to position FM. Tell me please what a have to do?
Jan 31, 2010 | Denon Audio Players & Recorders
Denon dra-95vr receiver has no sound out. All
Two things to check. First, the 95VR can be deceiving because it has a "variable loudness" control that some may mistake for volume. The actual volume is controlled by the big up and down arrows on the upper right side. If the volume is turned up, you should see the volume bar graph display show up. If none of the inputs are giving you volume, and the volume is turned up, then try running the output from the processor loop output in the back to another amplifier. The processor out is jumpered to the processor in for normal operation. Missing jumpers could cause a problem also. If there is sound coming to the processor out, then you have a problem with the power amplifiers. Best to refer that to a technician.
Dec 29, 2009 | Denon Audio Players & Recorders
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
No sound to speakers with power on
OK. That tells me that the output section is good. This may sound silly, but check to be sure that the tape monitor switch is not on.
Dan
Jun 06, 2008 | Audio Players & Recorders
Denon DRA-555 Memory won't hold set FM stations when powering up
Most probably the memory capacitor / battery inside soldered to pcb
Jun 06, 2008 | Denon DRA-455 Receiver
Old jvc home stereo
FM stereo will need a good aerial to work properly, but AM doesn't. If you have not got a good aerial, stereo will stay off. Though you might still here the station. It needs a lot of signal to make the stereo light activate. If was to come on in the weak state the sound would be full of interference. So the set keeps it switched off.
Oct 05, 2017 | Audio Players & Recorders
Tuner - When BASS it goes MONO
Did you check antenna connections?
Oct 09, 2007 | Denon DRA-395 Receiver
Lots of static when playing over the stereo speakers, and the screen seems loose
sorry but what u have is called a fm modulator some are adjustable some not go to your local car audio shop to find out or take your headunit out and look behind it if so tune the fm mod to a different station one thats not being used there are three preset station on the fm mod but remember just because theres no station on that radio channel were u live dont mean there wont be one when u go into town thats the bad thing about fm mods best thing to do is get a indash cd dvd radio and as far as the lose screen just hand tighten the screws flip down the screen look up there should be 4 or 6 screws there just tighten them up a little this is normal
Dec 18, 2006 | Farenheit MDM-830CM Car DVD Player
81 people viewed this question
 Grubhead
Grubhead
