Question about Refrigerators
It is a profile side by side model tfx25pabg and at the bottom of the freezer it gets a pool of ice that I need to keep breaking up and removing. if it goes too long, then i see a puddle on the kitchen floor. It is also frozen ice along the bottom back ledge. Any thoughts?
  • 4,066 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Posted on Feb 05, 2010
Testimonial: "it sounds reasonable but i probably need to get a service person as i am not very handy. thanks."
Drain tube blocked in freezer GE profile PDS22MCRBWW
This is a result of the drain being clogged. you'll have to locate the drain hole in the bottom of the freezer. Remove the wire bins and gently poke around the back of the floor of the refer with your finger. You should be able to feel a soft spot and clear the drain with a Q-tip or something else soft and flexable.
Dec 17, 2012 | GE Profile PDS22SCRL Stainless Steel...
Our icemaker just stopped working. I can feel ice
You need to replace the ice maker. If you could send a model we could get you the exact part number for that.
Thanks
May 23, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
The drain in the bottom of the freezer compartment seems to be clogged. It ices over an eventually and water drains out of the bottom of the door. It is a GE Profile. Is there a pan underneath that the...
You will need to remove the rear freezer wall I have a collection of photos I wish were mine but I do link them to their owners. So Follow me back to Sea Breeze Tip's and scroll to bottom of page where there are many ways people attempt a unclog the freezer drain. Sometimes it is slime build up that starts the cycle and sometimes the refrigerator is leaning a little enough to allow the water to pool on one side and creep as a frozen pool until the drains completely shut, One moment as I get the links Sea Breeze
Apr 10, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water accumulates in freezer bottom and of course frezzes. if we don't break up and remove the ice, water will leak out the door. best guess on the model below. The back panel states "R134a"
134a is the type of freon used. There is a defrost drain hole at the very bottom of the freezer usally below the back panel. It has a tube that runs underneath behind the back bottom of freezer section. It can get stopped up with slugg that keeps the water from getting to the defrost water pan. The water in the tube freezes and the water then runs out the front of freezer being it has no exit. . hot water or a hair dryer gun. If you have means to blow hole out after ice is melted will do a better job. Blowing warm water down hole through tube with mouth will knock ice out quickly but be very careful. also this ewill remove any trash build up in drain hole.
Mar 01, 2010 | Kenmore 57029 Side by Side Refrigerator
We have a GE Profile refrig, circa 1995. The ice
If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Smeg fride freezer leaking
HI Mark,
The evaporator drain is blocked causing the defrost water to pool, freeze and then leak onto your floor.
Clear out the freezer, then use a hammer to break up the ice on the floor. Now remove the rear panel. You'll see more ice build up. Don't use the hammer on it! (Too close to the coils for comfort) Use a hair dryer to warm up/melt the ice below the coils.
You'll see the drain hole now. Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
SG
Mar 27, 2009 | Smeg FA561X Side by Side Refrigerator
Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Mar 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE side by side refrigerator-1994
Check your drain pan for water.If you see none than you have a clogged drain line in the freezer.Remove the back wall lower screws and any screws that will prevent you from getting the back freezer panel off,NOTE : this is in the freezer located on the back wall. You will see the drain behind this panel , if its clogged ,un clog it.
Jul 23, 2008 | GE Profile Harmony DPGT750EC Electric...
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
