Question about Yamaha SW218V Speaker
Can you tell me how to conect my yamaha espeaker sw218v,do i need two.1200.wat amps.one for each one ordo i need a 1400,wat amp in order to have them work perfect or close to perfect!!thankyou truly,gabriel,!!
    Brigadier General:
  • 8,546 Answers
Power handling CAPACITY is not to be confused with power requirements. What they're getting at in the box "To protect your speakers" on Page 3 in the manual ...
When choosing a power amplifier to use with your speakers,
make sure that its power output matches the speakers’ power
capacity (refer to the Specifications on page 6). Even if the
amplifier’s power output is lower than the speakers’ PGM
(program) power capacity, the speakers may be damaged
when clipping of a high input signal occurs."
...is that any amplifier driven beyond it's non-distorting power limit will damage any speaker system, not with its raw power but with the artifacts of distortion (clipping). So they recommend amps spec'd at those high ratings in an attempt to keep them from distorting due to overdrive.
In practice, if you're cranking an amp to the stops you're either overdriving it or you're performing a concert and wishing you could crank it to '11'.
Being nominally 4-ohms, a pair of these speakers would likely have to be run in series or else their effective impedance may drop dangerously low. Two amps may be better for you, one amp per subwoofer.
If you need the manual, register with retrevo.com and download it free using "Yamaha SW218v" as the search.
Posted on Feb 06, 2010
HOW CAN I CONECT THE BOSE TO MY YAMAHA AMP THE ONLY WAY TO CONECT THE BOSE IS TO BANANA INPUTS ON MY AMP AND THEY ARE FRONT SPEAKERS BUT THE AMP HAS A SUB OUTPUT
To enable the full potential of a SUB for Yamaha DSP A5 ,
you need to have
a separate amplifier for your Bose Acoustimass System.
The SUB out should be connected to an active subwoofer.
Sep 30, 2012 | Bose Acoustimass 3 Series IV - 2.1-channel...
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
My Yamaha SW118 keeps cutting out (volume reduces to v low level) even when driven by 500W amp. Doesn't seem to be the amp but not sure if the speaker has it's own internal protection. Can anyone advise?
Poly Switch
All full-range loudspeakers are fitted with a self-resetting
poly switch that protects the high-frequency driver from
damage caused by excessive power.
If a loudspeaker cabinet loses high-frequency output, immediately
remove power from the unit and wait for two to three
minutes. They should allow the poly switch to reset. Reapply
power and check the performance of the high-frequency
driver before continuing with the power reduced to a
level that does not cause the poly switch to interrupt the signal.
On the SW115V/SW118V/SW218V sub woofer, the Poly
Switch protects the woofer and a similar routine should be
followed if its output is lost.
Aug 29, 2010 | Yamaha SW118-IV 18" Subwoofer Speaker
I have a ts-w307d4 pioneer sub woofer and its a 4 ohm sub that has 4 terminals on it 2 red and 2 black how do i wire this sub to my amp i have a sony 1200 watts stereo amp and my sub is a dual voice coil...
conect one of the positive terminal from the sub directli to one chanel of the amp, and do the same with the negative,and do the same with the others terminals from the sub conect to the other chanel
Aug 12, 2010 | Pioneer TS-W307D4 Car Subwoofer
I have two pioneer champions that are pushing 1200 wats a piece, how much wat amp do i need to push out the whole amount?
most likley they are 1200 peak if we r talking about the same ones then they are 400 rms a piece a solid 800 rms monoblock amp will poundem
Aug 16, 2009 | Rockford Fosgate Punch 401S Car Audio...
L7 wiring options
yes it should work fine i would bridge them up to 4 ohms each speaker then bridge them back bye conectin them on the amp by puting the red with the red and puting the black with the black if the amp only has 1 chanel then put both speakers red on the same positive on the amp and same with the negative now to bring the ohms up to 4 ohms conect the solid red to the black with dot with a short wire ok then the ones that are not run together will go to the amp giving offf 4 ohms and with the 2 speakers bridged together thay will reduce to 2 ohms witch means that eatch speaker will get about 600 wats of rms from the amp
Aug 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Knocking sound out of right side of yamaha sub
The speaker on the non-playing side is blown. Disconnect it or the amp will get fried as well. The coil has loosened from its form and is rattling against the speaker frame. If the insullation on the coil wires gets worn enough,it will short against the frame and possibly smoke that amp channel.
Dan
Mar 19, 2008 | Yamaha SW218V Speaker
Kenwood kac-9152d
by jump do you mean all it does is thump and no sound besides thumping noise? if so put a better ground on your amp, double grounds work the best. please reply
Oct 06, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Yamaha SW218V Speaker Logo
138 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
