Question about Dell Inspiron 1521 Notebook
How to reseat your hard drive - Dell Inspiron 1521 Notebook
  • 3,940 Answers
  • 617 Answers
Remove harddrive from pc, then re-install
Posted on Feb 05, 2010
How to reseat then harddrive
I'm unsure of why you would need to reseat a laptop hard drive - but it's easy to do in most laptops. Usually there is a rectangular cover on the bottom of the laptop - usually only 2 screws securing it. Remove screws, Remove cover, unplug hard drive, plug hard drive back in, replace cover and screws.
Apr 28, 2014 | Dell Inspiron Computers & Internet
Reseated hard drive, computer wont re-boot, asking for disc?
Check The BIOS to see if the hard disk is detected. If not then -
Check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 10, 2012 | Computers & Internet
How to reconnect harddrive
To reseat the hard drive on a Dell and it depends upon the model.
Most Dell hard drives are in a slot located behind a panel on the side of the laptop near the audio connectors. The hard drive panel/hard drive tray may be held in place with one or two screws. Remove the screw/s then open the laptop lid and pull/slide out the hard drive panel out. The hard drive panel has the drive tray and hard drive is attached to this panel.
Reverse this order to insert/reseat the hard drive back into your laptop.
May 14, 2012 | Dell Computers & Internet
Compaq presario v6000 computer does not detect hard drive storage
The hard disk may be faulty or it just needs reseating to make proper connection.
Reseat the hard drive and boot up your laptop. If it does not boot up then go into the BIOS configuration to see if the BIOS detects the hard drive.
If the BIOS deos not detect the hard drive then most likely it is faulty. In this case to get your laptop working again, replace the hard drive and install Windows on the new hard drive plus the Presario's device drivers and your programs.
Jun 21, 2011 | Compaq Presario Notebook
KEEP SAYING I DO NOT HAVE A HARD DRIVE when i do
turn the power off and reseat the hard drive and turn it back on to see if the system will see it. Also make sure you can hear the hard drive spin. If it doesn't after you reseated the hard drive you might have to buy a new hard drive.
Mar 03, 2011 | Microsoft Xbox 360 Console
My year and a half old inspiron 1525 came up with an "Internal Drive not found, try to reseat the hard drive". I tried to reseat the hard drive, but the same error comes up, and the computer...
Your hard drive is defective. The clicking noise you hear are the heads trying to load. For info on how a hard drive works copy and paste this link on your internet browser:
http://computer.howstuffworks.com/hard-disk5.htm
Feb 21, 2011 | Dell Inspiron 1525 Notebook
What does it mean when my laptop displays a message saying the internal hard disk can't be found and to reseat the hard drive
Reseat means take it out and plug in back in. On my 1525 the hard drive is at the top left when you flip over the laptop. You will need a fairly small Phillips (cross) screwdriver to remove one screw. Then take out the drive and check for any dirt - ideally using a small nozzle on a vacuum cleaner to give it a good clean. Make sure the power is off when you do this. Remove the battery first. Hint - the release mechanism for the battery is next to the barcode/serial number/service tag on the bottom of your laptop.
Jan 07, 2011 | Dell Inspiron 1525 Notebook
Hard drive
vostro 1500 every time i reseat the hard drive it works then i turn off the computer and turn it back on it gone again and im ask to reseat again and again
Apr 29, 2010 | Dell 160 GB 7200 RPM SATA Internal for...
Hi, You can try this out to reseat the Hard Drive
First safety Steps:
  1. Ensure that the work surface is flat and clean to prevent the computer cover from being scratched.
  2. Click Start before7.jpg , click the arrow before8.jpg icon, and then click Shut Down to turn off your computer.
  3. Disconnect your computer and all attached devices from their electrical outlets
  4. Disconnect any telephone or network cables from the computer.
  5. Remove any installed cards from the ExpressCard slot and the 8-in-1 memory card reader
  6. Turn the computer over.
  7. Slide the battery release latch until they click into place.
  8. Slide the battery out of the battery bay.
  9. Turn the computer top-side up, open the display, and press the power button to ground the system board.
    battery
1. Turn the computer over and remove the two hard drive screws.
screws (2)
hard drive
2. Slide the hard drive out of the computer.
3. Slide the hard drive into the hard drive bay until the drive is fully seated.
4. Replace the two screws to secure the hard drive Then again you can try
Feb 03, 2009 | Dell Inspiron 1525 Notebook
Acer aspire 4315
Take out the hard drive from the laptop and reseat it back into position. Sometimes reseating the hard drive will get it to be recognized by the BIOS. After you reseat the hard drive, go into the BIOS and see if its recognized in there. If it is then try to format the hard drive. If it still doesn't see it then your hard drive will need to be replaced.
Jan 31, 2009 | Acer Aspire 4315 Notebook
Dell Inspiron 1521 Notebook Logo
228 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
