Question about JVC Everio G Camcorder
Temperature to low
On the lcd there is a sign that says the temperature is too low and to wait. It will not go away. The camera will do nothing although it feels like it wants to work if the sign would just go away
  • 3 more comments
  • lesswords Feb 21, 2008
    this problem is fixed, I guess the temperature was too low after all
  • Anonymous May 24, 2008
    Me aparece en la camara que la temperatura es baja y que espere, pero espero y el problema no se soluciona
  • globalltd Jun 16, 2008
    When we turn the camcorder on there is a message on the screen which says the temperature is too low and to wait. We have left the machine on several times of a few days and the message remains and the machine will not do anything.
  • Anonymous Dec 21, 2008
    my camera says the same thing wat do i do
  • suludas Dec 21, 2008
    My JVC camcorder LCD displays a message that says " temperature is to low please wait" but the comcorder will not work and the message will not go away. Please help.
When we turn the camcorder on there is a message on the screen which says the temperature is too low and we have to wait. We have left the machine on several times and the message remains and the machine don't not do anything. Any Idea on how solve it?
Posted on Aug 10, 2008
Temperature warning
the temperature sensor may be faulty
Jul 13, 2008 | JVC Everio GZ-MG27 Camcorder
The camera (option m*5 pentax) got wet (on Songkran in Thailand). Now it works again except that it seems not to be able to load the battery. If I connect the battery charger while the camea is 'off'', the...
Normally when camera gets wet, first remove battery, use dry facial quality tissue to wipe water, keep camera in a/c so that whatsoever moisture inside camera evaporates due to low humidity in AC room for 24 hours . Take hair drier set in low heat mode holding minimum 6 inches away from camera blow warm air in battery compartment, mirror compartment, memory card slot for 2minutes each. Wait for cooling down to room temperature. Put battery switch on. It should work. Wet camera if you switching on main board get short due to flash voltage in side camera.
Sep 25, 2017 | Pentax Optio M85 Digital Camera
My camcoder (jvc gz-mg575ag) camera temperatur is to low keep camera power on plase wait! Now what I do?
its probibly early signs of condensation or a little damp air with faults of this nature same as lense cap fault and or condensation fault leave camera plugged in and switched on for a week . when camera has been on for a while dont put it straight into a bag or case leave it a room temp for a couple of hours after use before putting it away .
Jan 21, 2011 | JVC Video Cameras
I have a keurig b 60 brewer and i don't feel the water is hot enough. i just got it last night 12/23/10 can u suggest anything?
Sorry to read about your problem, I hope this helps you out.
ProgrammingBrewTemperature (187°-192oF)
The Brewer brews at a preset temperature of 192°. You can adjust this temperature down by 5 degrees if you prefer a cooler cup of coffee, tea or hot cocoa. Simply follow the instructions below.
1. Press the Menu Button on the LCD Control Center five times to program the Brew Temperature feature.
2. The LCD Control Center will now display the programming options with a small arrow next to "SET BREW TEMP" (fig. 15). Also, the temperature 192° (initial setting) will be displayed at the bottom of the LCD Control Center to indicate the current temperature setting.
3. A minus sign will appear over the Small Cup Button and/or a plus sign over the Large Mug Button. Use these buttons to raise or lower the temperature one degree at a time.
4. Once you have reached your desired brew temperature, press the Menu Button once to exit the programming mode. "BREW TEMP SET" will be displayed in the LCD Control Center if you have changed it from 192°.
5. To change the brew temperature again, repeat steps 1 through 3 to change the temperature up or down, remembering that the temperature can only be between 187° and 192°.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Keurig B60 Coffee Maker
When i open my cam it shows" camer has too low temperature
You may at extreme low temperature that cause your camera freeze. Check the temperature working range in your manual.
regards
Dec 17, 2010 | Cameras
JVC Everio GZ-360BU Camera Temperature is Too Low - Keep Power On??
I'm an English guy with the same problem... What you do is keep the power on for a long time, or you charge it up with the charger. Trust me. However, it is very rare for this to occur. There should be a message saying: "Temperature is too low, keep power on." There should be another message reading: "Turn off power and turn on again to check if camera is fully-functional. Thanks for giving me something to do while X-Plane downloads on my Mac OS X.
Oct 31, 2008 | JVC Everio GZ-MG30 Camcorder
Camera Temperature
mine is an everio gz-mg37u and i get that same bulls*** on the screen at every power up. First I tried waiting a while then switching all the switches between camera and video mode, record and watch mode, etc. and one time it worked and the message went away. Haven't been able to do that since.
Now what I do is turn it on, wrap it in a blanket, leave it about 10 minutes, then turn the power off and on again. Works fine for me, and if I turn it off and then turn it back on within a few minutes before it cools down, it works fine. There has to be a messed up sensor in this thing that I can desolder somewhere......
Jun 13, 2008 | JVC Everio GZ-MG130 Camcorder
What is the type of LCD monitor display?
The DiMAGE A2 has a 46mm (1.8 inch) low-temperature polysilicon TFT color LCD Monitor, which displays approximately 118,000 pixels. This LCD monitor is tiltable (20 deg. downward and 90 deg. upward).
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
The DiMAGE A1 has a 46mm (1.8 inch) low-temperature polysilicon TFT color LCD Monitor, which displays approximately 118,000 pixels. This LCD monitor is tiltable (20 deg. downward and 90 deg. upward).
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
JVC Everio G Camcorder Logo
482 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
