Question about Mitsubishi WS-55809 55" Rear Projection Television
Convergence service problem
Every color is alone the colors are not complete
same problem - colors all separated
  • Anonymous Mar 03, 2008
    same problem with colors spliting and picture appearing warped. what do you do to fix this?
    Sergeant:
  • 395 Answers
Need to replace the convergance amps they are STK392-570 there are two of them they both have to be replaced also some resistors may need to be replaced. the cost of the repair mey be $ 350.00
Posted on Feb 21, 2008
    Sergeant:
    Champion:
  • 301 Answers
Check for any cracked solder on the middle power board of the chassis on the convergence ICs located on the large heatsink. make sure that you dont let this fail go on for too long becasue it will cause some fuses to go bad.
Convergence ?
IF THE COLORS ON SCREEN ARE SEPARATED, OR BLURRY, OR YOU SEE SEPARATE COLORS ON SCREEN. DO A GOOGLE SEARCH AND YOU SHOULD FIND CONVERGENCE PROBLEMS ON TV'S AND WHAT IT LOOKS LIKE. THERE ARE CONVERGENCE KITS AND EASY INSTRUCTIONS.
Nov 11, 2013 | Sony KP-61V90 61" Rear Projection...
Periodic color scrambling - out of focus. Seems as though the different colors separate and get out of focus.
Ur tv is having a convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Hitachi 50GX30B 50". Rear Projection...
The colors are separated. Images are blurry and
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 24, 2009 | Sony KP-51WS500 51" Rear Projection...
Color is separating (red and Green double images
Yes everything is repairable.....
The problem is in the Croma section of the TV
some times it ma happen due to 99% of moisture.........
Try Hot air Blow drying for 1 HR in side the TV i.e on the circute and blow clean if any dust partical are there
and then re check
if the problem prestis....contact the TV repai expert or the service centre....
May the Croma chip needs replacement....
Regards
Sep 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Philips Projection TV the colors are separated- not converging
This was hapening to me too. To fix I just punched the tv. If this works then some wires were disconnected. Punch the right and left side not the screen or the back it will damage!
Apr 07, 2009 | Philips Televison & Video
Colors are separated on the top from the left to right
Probably the color convergence is off. I had a similar problem. Have you tried the magic focus button yet? That is located at left in the small front control panel. Power on TV, wait 20 min (according to user guide), then press the magic focus. If that doesn't fix the problem, you could try the service mode alignment procedure. But that's a little trickier. I don't have a link handy for that procedure right now, but will look for it if magic focus doesn't re-align your color convergence.
Jan 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Panasonic PT-47WX49 47" Rear Projection...
TN55X81 Rear Projection color separation - convergence problem
You shouldn't need to do a board replacement, all you should need to do is manually tune the convergence.
You can do this with the built-in user tool, but there's also a far more powerful set of options in the service mode. To save you the trouble (I advise doing a LOT of reading before attempting any of this) here's a solid set of various tutorials based on what form of "separation" you have occurring:
http://www.keohi.com/keohiHDTV/brandspecific/toshiba/servicemenu/servicemenu.html
Nov 21, 2007 | Toshiba 55H70 55" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
