Question about Denon DRA-397
How to play my Droid mp3 music through my DRA-397 receiver
I have a Denon DRA-397 Stereo Receiver. I want to play music from my MP3 player (Droid) through my receiver to the sound system in my house. The Best Buy guy said all I needed was a mp3 audio cable just like plugging into my aux in my car. But it doesn't work at all. Help!
Eric
  • 395 Answers
SOURCE: connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
Posted on May 21, 2008
SOURCE: Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Posted on Dec 30, 2008
  • 119 Answers
SOURCE: denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Posted on Mar 02, 2009
SOURCE: Panel Lock On. How can I turn it off?
make sure unit is off then hold down spker b and mode buttons and then turn it on
Posted on May 22, 2009
SOURCE: I HAVE A DENON DRA-397
Make sure you are using the main power button not the standby button and you should be fine
Posted on Jun 27, 2009
I have an old Denon stereo receiver DRA - 565 RD. Do you know how I can connect my iPhone to the receiver to play music from my iPhone?
You need a 3,5mm male stereo connector to RCA male jacks (see attached image). Plug the 3.5mm jack to your iPhone and the RCA jacks (red & white or red & black) to your Denon Receiver's CD in or Tape 1 or 2 PB (at the rear of the unit). Then select the input where you plugged the RCA to (front of receiver: CD / Tape-2 / Tape-1). Hope this will help. 25303676-z0ul41frrnrex4ege2epffps-1-0.jpg
Dec 02, 2014 | Denon Audio Players & Recorders
I have a denon DRA-397 receiver and when I try to bring it out of standby, it attempts to restart then returns to standby after the tuner starts up. The standby button has a flashing red ring rather
When the power indicator is blinking red, there are a few possible issues. 1) The unit has overheated internally due to insufficient air flow around the unit. Let it cool down and then make sure that you have it in a well-ventilated area. (If you keep your home theater devices in a "closet", make sure that you have good air flow so that the heat from all the devices doesn't build up.)
2) The speaker wire cores are touching each other or the back of the unit. The DRA-397 will shut itself off if it detects a short of the speaker wires. Check the connections and make sure that the wires are not touching where they shouldn't.
3) An internal short or fault has been detected. In this case, contact Denon for repair.
I hope this helps.
(Based on setting up our systems, it can be easy to have a loose speaker cable.)
Oct 17, 2012 | Audio Players & Recorders
I have a Denon DRA 397 receiver and when I power it up the standby light goes on but nothing else powers up?
If you are not pressing the power button on the remote that may be the problem
Apr 11, 2012 | Denon DRA-397
Is the denon dra-395 compatible with an ipod?
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Feb 13, 2011 | Denon DRA-395 Receiver
We bought our Denon 395 4 years ago. Is it set up for HDTV and IPhone (IPod) use? Also, how can we get a manal as it was lost in moving. Charles Barrett cbarrett1410@yahoo.com
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-DRA-395-Receivers-manual/id/363ci767/t/2/
It is an analog STEREO-only receiver so it is NOT compatible with multichannel or even digital audio. The TV is irrelevant.
Re: the iPhone:
Dec 29, 2010 | Denon DRA-395 Receiver
DRA-345R stereo receiver. FM is gone, poof! just like that. nothing looks burned. where do I start? No change to the antennae has been made
I have a denon DRA-345R and when I put on position mode cd I can listen music and then after 1 minute the mode change automaticly to position FM. Tell me please what a have to do?
Jan 31, 2010 | Denon Audio Players & Recorders
I have a Denon DRA-397 Receiver. It was stuck with the "Panel Lock" but I followed the instructions here to hold the "B" and "Mode" buttons while powering on. It unlocked the panel. Now the Reciever is...
Check for a reset of the receiver. If no mention in manual you might want to check with the manufacturer for a code . If nada then the electronics are fubar and you are SOL.
Aug 31, 2017 | Denon DRA-397
Denon DRA 397 Won't Turn On
me too did you ever get it fixed
Dec 16, 2008 | Denon DRA-397
Denon receiver (DRA 397) will not speak to iPod dock
Oct 13, 2008 | Denon DRA-397
Apr 12, 2008 | Denon DRA-397
Denon DRA-397 Logo
284 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
