Question about Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN making beeping noise when out of paper
Samsung CLX-3160FN making beeping noise when out of paper and open door
SOURCE: Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
Posted on Feb 07, 2008
acdr
  • 1913 Answers
SOURCE: keeps jamming
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Posted on Oct 09, 2008
yooperbud
  • 8637 Answers
SOURCE: CLX-3160FN Paper Jam when there
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
  • 220 Answers
SOURCE: CLX-3160FN askes for replace TRansport belt, is it a
replace belt,take drum out slide transfer belt wich is located ontop of drum.see how it is connected,slides in/out.
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: Constant Paper jams on CLX-3175FN
Where is the jam happening? Is it right at the print output tray? If it is, where only about 1/3 of the paper will comeout and stop printing, the 2nd paper sensor right about that area is defective. If you're unit is still under warranty, a service call to samsung is needed to get the part replace.
Posted on Aug 16, 2009
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
My samsung clx 3160fn prints with a faded streak in the center of the paper
There is some-thing that is dirty that is making contact with the paper.
My guess is a roller or a little metal guide wheel or the like.
Clean it with tissue paper.
Use the already printed page to line up to see where about the source of the line is comming from.
Till next time!
damnor01
Apr 14, 2011 | Samsung CLX 3160fn All-In-One Printer
My Samsung scanner says "Scanner Locked" What does this mean. It makes a loud clicking noise like it is about to breakdown. juliakrebs45@yahoo.com
If you look into the paper output of the printer you find a green lever. Pull it to the front. Open scanner lid and check the position of the lever.
Restart printer by switching off and on again.
Oct 20, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a Samsung CLX-3160FN, and after every page
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
May 15, 2010 | Samsung CLX-3160 All-In-One Laser Printer
My printer samsung CLX-3160FN, does a strog
There is mechanical problem with your printer so that printer need servicing.
Feb 24, 2010 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160fn won't print
Usually I've seen that happen when you use generic toners. There are 4 toner clutches down the right side, with the right cover off you can see which clutch is doing the grinding. Many of the generics are overfilled and hard to turn and will make the noise until you loosen them by hand turning them til they loosen up, or just replacing.
Dec 28, 2009 | Samsung CLX 3160fn All-In-One Printer
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Jan 04, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
42 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
