Question about Exercise & Fitness
I have a Proform 530x that will run fine for about 40 minutes @3.5 MPH then belt will stop. If I step off the belt it will come back up to speed until I step back on. Then it stops again. Removing and reinserting the key seems to fix the problem for about 10-15 minutes. The motor seems to be much louder now. I removed the drive belt and let the motor run freeIy and it remained nosiy. There does not seem to be any excess play in the motor or belt bearings. However, the motor was easy to stop using my the sole of my shoe with little pressure. On top of all this it seems to happen about 7 out of 10 times. Thanks for any help or ideas you may have.
    Genius:
  • 1,341 Answers
It is very clear that the motor is naked and needs maintenance work or else best would be a replacement.A motor which is meant to do this kind of task should not stop turning by a sole of a shoe and that too with only little pressure, which clearly means it has not got enough power.Hope this helps.
Posted on Feb 05, 2010
I have a proform 580 trainer whose speed fluctuates. if it is set to 4 mph it will go down to 3.2 mph then back up to 4 mph and anywhere inbetween those speeds.
1) Tess by RUN the sofware calibration for easy diagnose, troubleshooting and fix it.
2) adjust the speed sensor, test for open or faulty, clean it and tight the plug very well. see the diagram attached.
3) Test the inclination motor for overheating Try to LUBE
4) Lube the deck belt according with the schedule maintenance.
God bless you
Dec 18, 2012 | Proform XP 580 Trainer Treadmill
I replaced the belt on the Proform 530x and it still sticks. I have also tried to silicone spray the deck,. Help ?
You must LUBE very well the deck belt. 2) adjus the roller bearing and LUBE very well 3) Motor can be LUBE follow the instruction manual for LUBE. 4) Adjust the deck belt see the diagram.
sincerely. God bless you.
Apr 23, 2012 | Proform 530 Treadmill Walking Belt
Treadmill starts at 2 mph runs for a second then shuts off
1)The walk belt lift 3-4"aprox, you must adjust the tension.
2) Read your user manual and proceed as indicated.Tense the drive belt.
3) if the problem persist you will have electronic+ electric problem with the main motor controller board + motor . Test it
sincerely.
Dec 13, 2011 | Treadmill Doctor PROFORM 540 TREADMILL...
I have a PROFORM CX 500 at my home. It used to work fine but now there is a strange striking sound coming out of the front chamber when I run it at a spead 6 km/h or above. And with the sound you can feel...
You must LUBE the roller bearing front and back with WD-40 very well. .
2) Examine the drive belt motor, if are very tight, must be deflection 1/8" other wise the ball bearing of motor are very tight.Tight very well the bolt of motor.
3) Run again, if the problem persist, the Rollers are Faulty. Replace.
Treadmill Repair worn belt roller bearings
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 21, 2017 | Proform Crosswalk 500 Treadmill
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
May 27, 2010 | Proform CrossTrainer Treadmill
It started making a loud noise and when I turn it on and step on it it doesn't even run...what can I do?
Hi, did you fix you treadmill's loud noise?
I have a 530X Proform and I'm having the same problem with my.
May 21, 2010 | Exercise & Fitness
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
How do you calibrate a ProForm 530x Treadmill?
To calibrate the speed and/or incline, please refer to the instructions that are under the motor hood cover or are mounted on the inside of the belly pan. Be sure to unplug your machine. If the instructions are not there, please contact our customer service department at {~1-888-533-1333} while you are near your machine.
Apr 10, 2010 | Proform 530 Treadmill Walking Belt
Unit powers on but belt won't move (motor problem?)
You problem is with the motor controller. If everything works but belt want turn 99% of the time it's the motor controller. Call if you'd like more information. 404.456.2327
May 05, 2009 | Nordic Track /proform Treadmill...
Exercise & Fitness Logo
132 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
