Aspes Ideal 143 whashing machine in spin dry mode
Aspes Ideal 143 whashing machine works normally but in spin dry mode does not spin
philbran
  • 242 Answers
SOURCE: Washer sometimes will not spin dry.
Hello , this is the first sign of your clutch going out , it is not engaging on the last spin cycle soon it will almost never spin. the clutch is tough to get to and is not much money. you would have to be willing to pull the gear case to replace the clutch. a repair company would charge around 150.00-200.00 dollars total. Here is a different look at your problem follow the link I added , it is part # 5 as a kit.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0307038-00004.png
Please ask any questions you may have.
Phil
Posted on Jan 12, 2009
  • 20 Answers
SOURCE: Hotpoint WD63 dryer not working
Hi Jacky, Please make sure the power is off and unpluged.On the rear of the heater element board you will find a thermal cut out switch (it's about as big as a 5p piece with an oval outer body) what happens is the heaters overload and pops the bimetal switch, on the back of the switch you will see a small hole just big enough to fit a pin in, get a pin and gently push the bimetal disc and it should pop, if it does then you are fixed.
Posted on Mar 10, 2009
  • 25 Answers
SOURCE: Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Posted on Apr 07, 2010
  • 6277 Answers
SOURCE: HOW TO CLEAR PUMP ON ASPES 143
Sorry, I do not know your particular machine BUT here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 09, 2011
heatman101
  • 43501 Answers
SOURCE: Aspes LA 143, will not
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Apr 23, 2011
My Maytag Neptune MAH8700AWW washer when in the spin dry mode shuts down with a suds error?
Check your drain hose for kinks or blockages, check filter and pump for blockages, check wire harness connections to pump, pressure switch and CCU.
I machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Washing Machines
Hoover vhd sensor dry 59 minute programme not working
"Rapid W&D 59 Min.
When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
If the other cycles work without issue, it in not faulty.
Check the wash weight.
Sep 20, 2017 | Hoover Washing Machines
Aspes LA 143, will not drain water
heatman101
Apr 23, 2011 | Washing Machines
John C
Mar 09, 2011 | Electrolux AWF 1435 Front Load Washer
My top load kenmore whashing machine is not spinning on during the wash cycle. but works well during other cycles
if the water isn't draining and it's not spining you have a bad lid switch.get back to me and let me know if this is what's happening,you can stick a screw driver in the hole where the lid closes down into and see if it spins.
Feb 01, 2011 | Kenmore Washing Machines
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Apr 05, 2010 | Washing Machines
800 series , pomp and spinning is ok but whashing not working
sound like your speed control switch on the console that you set and if not your timer is going out but the switch is only a few dollars and thats what i'd do first.
Larry
Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
172 people viewed this question
Top Washing Machines Experts
