Question about Ovens
My jenn-air oven keeps peeping and displaying the message -F 1- . if I push the cancel/off pad the beeping will go away, but sometimes it will start beeping again shortly after. please advise.
30" No.W46K03 or 318200413 S/C range.
When the bake is press and the timer is push to 400oC it instantly dropped to 100oC and takes 4hrs. to come to 250oC instead of 400oC . Please advice me
Posted on Feb 06, 2010
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
Jenn Air double oven keeps beeping
HI,
The problem is with the faulty relay board or wire harness harness.
There are no home remedies for this problem.The only solution is to get it repaired.
Sep 17, 2008 | Jenn-Air Electric Double Oven
My oven keeps randomly beeping and flashing F-1 recently. When I push cancel it stops, sometimes for an hour and sometimes for a week. I have tried to reset by turing circuit on and off, but problem does...
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
May 11, 2011 | Maytag Ovens
Jenn-Air gas wall oven some how got stuck in ''Sabbath'' mode and unable to reset.
ok it happens / so to enable the Sabbath mode 1 open the door. 2 press cancel/off. 3 press the number pads 7&8 and 9 , in that order. 4 press Number pad 6 . 5 press start. "sab and on" will appear on the display ..( now to disable the sabbath mode .}. ( repeat the steps above to disable the Sabbath mode. " Sab and off" will appear on the display .. there now that wasn't too tuff was it .. mm hope this helped ..
Jul 15, 2010 | Jenn-Air Ovens
Oven W279U Serial No. 790191BD keeps beeping.
I turned off the power to the oven at the breaker box and left it off for several days. I restored the power this afternoon and there have been no more beeps. Spells and incantations may have played a part as well.
Aug 20, 2009 | Jenn-Air Ovens
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Beeping and F7 when cleaning
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
Beeping sound showing f 1
HI thanks for your question. F1 means that the touch pad is faulty. it says to replace the touch pad. thanks .please rate my answer thanks.
Oct 07, 2008 | Jenn-Air JJW8530C Expressions Collection...
Error code F1
I had the same problem and found this post:
http://fixitnow.com/wp/2006/03/11/maytag-amana-jenn-air-and-magic-chef-range-f1-codes/
The oven had been cleaned earlier in the day and the touch pad ribbon connector was shorting. I cleaned it with rubbing alchohol and blow dried the whole board for good measure. Hooked everything back up and haven't had a problem since.
Jun 08, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Electric Oven - F-1 Code
You can disconnect the beeper so its not so annoying. turn oven off at breaker first. pull out oven a little so you can get at the top 2 screws on each side. The speaker is between the boards on the display module.
look for a red wire connected to a gold disc like speaker. remove this wire and you won't hear the beeping anymore.
Nov 27, 2007 | Jenn-Air JGW8130A Electric Single Oven
Ovens Logo
116 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
