Question about Miele 23 in. Novotronic G841 Built-In Dishwasher
The drying vent on the front of our miele dishwasher is leaking water and the fan is making a lot of noise at the end of cycle
  • 177 Answers
if you remove the door panel you will see a small hose from the fan to the combi dispener. Remove this and blow through it. Also connect it to the combi dispener and blow and then to the fan end and blow. Food and muck block the pipe and the excess water cannot escape back into the unit so instead it pours out the vent. you will find the fan is then quieter.
Posted on Mar 02, 2010
    Novelist:
  • 269 Answers
Like the guru above said, you have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked before.
Posted on Jan 26, 2011
Why does my new dishwasher not dry dishes completely?undefined
Mieles do not have a drying element - this is a big energy saver. They save heat from washing and use that to dry the dishes. Sometimes they will not be quite bone dry at the end of the cycle, but most will be dry if you open the door for a little while to let air circulate.
If your vent (port on the front) is blocked then the machine will not be able to blow out the damp air, and you will have wet dishes as you describe. If you have leaking from that port, then check my answers on "the Miele problem" which I am pasting below.
You have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is an idiotic problem that Miele should have a permanent fix for. Grrrr.
If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk.muck and slop.
Doggone design sucks on an otherwise nice machine!!
Sep 29, 2014 | Miele Dishwashers
Door vent spitting water
Sounds like you have the Miele Problem.
The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service, but it is easy to learn to do it yourself. It can be done at home with no added parts. I think it applies to all Miele dishwashers, at least for a number of model years, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk, muck and slop.
Apr 02, 2014 | Miele 24 in. G692SC Plus SS Free-standing...
Hi Service, I have a Miele dishwasher model G692 SC Plus which has a problem with the drying fan filling with water during the wash cycle. We open the door at the end of the cycle and water drains out...
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked several times before.
Jan 16, 2011 | Miele Dishwashers
Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
Jun 27, 2010 | Miele 24 in. G693 Free-Standing Dishwasher
It leaks from the left side when washing dishes
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dddg
Nov 22, 2009 | Miele Touchtronic G892 Built-in Dishwasher
Drying cycle vent fan is noisy. How can I fix it
I had the same issue but mine is an inbuilt unit. I removed the 4 screws for the front main facia panel which was then removed. Following this I removed the 6 screws that hold the plastic control cover in place and then the three screws (1 top centre and 1 on left and right) that holds the control plate which I then gentrly lowered.
I then used a flat blade screw driver to turn the inside fan cover anti clockwise about 45 degrees which allows the fan module to be removed. Then disconnected the drain pipe at the fan module only and power and control cables.
I then blew the gunk out of the fan module and gave this a good wash through with hot water to ensure it was clean and then dryed with paper towel. I then also blew out the drain pipe. The remaining gunk was blown into the interior of the dish washer out a vent just below the rinse aid unit.
If I need to do this again then I would have removed both ends of the pipe and washed this through with hot soapy water to make sure it was clean.
To reassemble do the reverse process. Assistance will probably be required to reassemble the front main facia panel as one person would need two hands to hold in place and another to locate and start the screws. A couple of clamps could over come this.
Dec 31, 2008 | Miele 24 in. G865 Built-in Dishwasher
Miele G868 dishwasher - leaks from front panel air vent
Hi all,
I have had the same problem. Here is what I've done. Take the door apart (a whole bunch of screws on the side of the door). The front panel will come off and you will see a rubber tube. Take it off and blow it out. Then take the blower out (you need to unscrew the inside of the blower). Take apart the blower and clean it out.
Good luck.
Jun 09, 2008 | Miele 24 in. G870 Built-in Dishwasher
Miele dishwasher drying problem
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
Mar 30, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele 23 in. Novotronic G841 Built-In Dishwasher Logo
863 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
