Question about Kitchen Ranges
Kenmore C880 6587590 burner switch replacement.
I need to replace a couple of burner switches on my electric range but can't get access to the back of the switches. There is no obvious back panel to remove and it doesn't look like I can get access from the front. It appears that my best option is to remove both plastic side panels. But how do I do that? Alternatively, where can I get a repair manual for this stove?
I just replaced the switch just yesterday.First remove the glass panel by pushing back the 2 black clips at the top end,then remove 2 silver screws at the top and 3 at the bottom also remove 2 black screws behind side panels on the top. Now push side panels slightly up and forward and it fill fall forward and now replace the switch.
Posted on Aug 26, 2009
Remove two Philips screws inside the fuse compartment, pull up and fold forward.
Posted on Jun 21, 2008
Kenmore electric range
Probably the switch. Change for another burner to see if the element is ok.
Dec 01, 2013 | Kitchen Ranges
Kenmore 79096011407 ceramic cook top. When front left burner is turned on, it goes to high and does not turn off. Had to use main breaker panel to turn off electric to the range. Can not find parts list...
Sounds like the switch for that burner needs to be replaced. Its possible that something else may be shorting out but usually its just the switch. Your ranges burners and switches are standard switches and burners for this type of range so the switch should fix it. Hope that helps.
Aug 29, 2011 | Kitchen Ranges
Hiya:) I have a kenmore electric stove model #362.922123Q1 w/a bad burner in it and i have replaced the burner and the receptacle to no avail:( can someone tell me the next step in the diagnostic...
Having replace those two parts the switch is bad,if you have a multimeter you can check the switch by setting the meter to the ohms setting and TURN OFF BREAKER TO THE STOVE OR UNPLUG access the switch by removing the back panel and set the switch to the HIGH setting ,then remove the wire off marked H1 and L1 and check for contuninty by placing the meter leads on those two terminals,then reinstall the wires on those and remove the wires off of L2 andH2 and check for contuninty there, if no contuninty on L1 to H1, or L2 to H2 then the switch is defective
the part# for the switch for the large burner is WB24T10027
the part # for the switch for the small small burner is WB24T10022
Jul 23, 2011 | Kenmore 91112 / 91114 / 91117 Electric...
The two large electric burner is not working.I switched the burners and they work on the small burner.
This receptacle block get burnt up. Replace them.
THIS will work on any brand stove. If the receptacles are fine then the switches must be bad. Here is how they all work:
Jun 07, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Electric range surface light stays on
When the burner went, it took out the switch that controls it. The contacts inside the switch have welded together. That switch needs to be replaced. You should also look at the receptacle that the burner plus into. That may have been the original cause of all the problems. The contacts in them often wear causing the burner to src inside the receptacle. These parts should be readily available from Sears: burner control (infinie) switch, Burner receptacle.
Apr 09, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Element does doesn't switch off.
What your going to have to do is replace the infinate control for that burner. ( thats the control you turn to sw it from high to low heat )
good luck
Jan 07, 2009 | Kenmore 96212 / 96214 / 96219 Electric...
Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Jan 03, 2008 | Kitchen Ranges
Kitchen Ranges Logo
1,209 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
