Question about Linksys WRT160N Wireless Router
Which model of the Linksys N router will you recommend best for video streaming [This Home Use]
  • 136 Answers
In the order of preference
1) WRT610N
2) WRT310N
3 )WRT320N
Posted on Feb 06, 2010
BUFFERING SLOW, THEN PICTURE COMES THEN DROPS.
You probably have a slow internet connection. It is recommended that you have a minimum 25/25 Mbps connection from your provider. If you do then the streaming stick might be too far from your wireless router. Try to move the router closer to the Streaming Stick if possible. The best way to watch streaming video is with a wired ethernet connection with a Roku 3 or other wired device. Good Luck!
Jan 01, 2015 | Roku Streaming Stick HDMI Version
My Linksys WRT54G router is dropping the signal
Very old router. I suspect a failure. I recommend you check out this website to see if there is any hope for it.
Linksys WRT54G stuck in self diagnostic mode lol
Feb 04, 2018 | Linksys WRT Computers & Internet
We have cable internet,what is the best wireless router to cover a big house
I would suggest Linksys: Linksys and Cisco have the same manufacturer...
http://www.google.com/#q=linksys+wireless+router&hl=en&prmd=ivnsr&source=univ&tbm=shop&tbo=u&sa=X&ei=nzZPTvv-BpOssAKDruDrBg&sqi=2&ved=0CFcQrQQ&bav=on.2,or.r_gc.r_pw.&fp=1f2b48236847be08&biw=924&bih=518
use wireless N routers
but if you have a lot of money to spend wireless routers plus repeaters is the best set up...
hope this helps...
by the way i work for AT&T 2-wire home networking specialize in wireless connection... dealt with a lot of wireless routers so far linksys is the best... though its costs also speaks for its Quality...
Aug 20, 2011 | shaw.ca
Unable to stream novie sites with my linksys wireless-g router
Check the connection (signal) strength of your wireless connection in the status area of the task bar in Windows. Also, hovering the mouse over the wireless connection should reveal the connection speed. 54mbps is the highest you can expect on a wireless connection, which is generally OK for streaming video..Any less of a signal strength/connect speed will likely not be adequate for streaming video.
A poor signal strength is usually because of too much distance or too many walls between the router and the computer.
Hope that's helpful.
Jan 15, 2011 | Linksys Wireless-G WRT54G Router
I have had problems with streaming video during
Doing my best to give you a correct solution and understanding
Issue : delays in streaming video
Environment :
ISP : Bellsouth
Router : wireless WRT150N
Solution :
"Downside to streaming"
Traffic jams.
Internet isn't a direct pipeline from the source to you. Streamed content passes through many other computers on its way to your computer via your ISP. If any one of them is carrying too much other traffic, the streamed content may be interrupted and pause. Streamed content is "buffered" to help avoid this, but sometimes it's unavoidable.
(test the downstream and upstream speed and alose test the download )
(Checked deleting the temporary files and folders)
(Checked firewall and Anti virus)
A slow computer :
if you have too many applications open, it could slow down your media streaming. If you notice things are sluggish, close all unnecessary applications and windows running on your computer. Just keep your Web browser and your media player open.
Noisy phone lines.
phone line that isn't free of noise (humming, crackling), that's not good for streaming (or Web browsing). Disconnect any phones that cause a buzz or hum.
Jan 02, 2010 | Linksys WRT150N Wireless N Router -...
I'm having problems not only with registration but also connecting the router.
Kindly follow the below steps to setup your router, this will help
LinkSys Router Setup Physical Setup of a LinkSys Router Each model of LinkSys router will differ slightly, but the general design is similar across all models. Therefore, the setup is similar across all models.
  1. Attach the antennas to the router (if your LinkSys router support wireless)d
  2. Plug the Ethernet cable from your broadband Internet provider into the port labeled "Internet"
  3. Plug another Ethernet cable into one of the available ports
  4. Plug the other end of that same cable into an Ethernet port on your PC
LinkSys Router Configuration LinkSys routers now ship with a Setup Wizard which is intended to simplfy basic configuration tasks.
We do not recommend the LinkSys Setup Wizard for two reasons:
  1. The Setup Wizard is not significantly easier that the regular configuration menus
  2. If you use the Setup Wizard, you will end up learning two interfaces for your LikSys router instead of just one
Instead, we recommend simply starting your web browser and jumping into the configuration.
Once your web browser is open, go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password.
Logging in to a LinkSys Router
The username is either blank or "admin" and the default password is "admin".
Once you are past the login screen, you are able to access (and change) a plethora of configuration options for your router.
Don't be worried by the enormous number and variety of options, your LinkSys router ships with default settings that enable it to work right out of the box in most environments.
From here the configuration options that you choose are largely up to your own personal preference.
If this is a wireless router, we recommend that you consider setting an SSID to identify the router as your own and configuring WEP to encrypt your wireless traffic.
Let me know if this will help
Regards
I can provide you more on Linksys router as i work on them :)
All the best
Nov 29, 2009 | Linksys Wireless-G Broadband Router
How do I set up my Linksys router?
LinkSys Router Setup Video Tutorials Learn how to set up your Linksys Router.
Thomas installs a Linksys router to demonstrate what ease-of-use means.
I really hope this information is helpfull.
Aug 12, 2008 | Computers & Internet
Need to be able to stream
This patrticular b router from linksys is a older version, it is not compatible for certain products, try upgrading the latest firmware for the router through, www.linksys.com/downloads, or else replace the router and check..
Jan 20, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys WRT160N Wireless Router  Logo
93 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
