Question about Lexmark Color JetPrinter Z52 InkJet
Replaced ink cartridges in Lexmark Z52. Noe ink
Replaced ink cartridges in Lexmark Z52. Now ink carrier slams to left or right and I get a "power surge" error message. I have disconnected and removed/replaced power and problem still exists.
    President:
  • 949 Answers
There should be a clean program that you can run.
First restart windows, then run the clean program,
see if this helps, try and print. If you need more help
re-post what you did and still have a problem.
Posted on Feb 05, 2010
Lexmark 5400 cartridge carrier slams up against back???? Won't stop!! It's a new printer, put in a high cap black and low cap color cartridge. Any ideas how to fix this?
Cartridges may not be seated properly. Remove all the cartridges from the printer. Close the cover. Unplug the printer from the power source. Wait for about 10-15 seconds. Plug printer back to power source. If printer ink cartridge carrier still slams on the sides, encoder strip of the printer might be damaged. If it's still within warranty from where you bought it, have it replaced at that store. If ink cartridge carrier is not slamming to the sides, re-insert the cartridges. Make sure there are no obstructions along the carrier's path. Close the cover. Let the printer print the alignment page. If it's still going to slam the carrier, have it replaced.
Apr 07, 2010 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
Lexmark x83 carrier stall
Hello there.
I have checked lexmark's website on troubleshooting this problem for you.
As per the link here we need to try the following steps to resolve the problem.
Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 null.gif null.gif null.gif
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, you may need to contact Lexmark Technical Support.
Let us know how this goes and we can assist you futher, if the printer is damaged and is under a year old, lexmark may be able to repair or replace it for you.
Hope this helps.
Jun 16, 2008 | Lexmark X83 All-In-One InkJet Printer
Lemark Z52 Inkjet
Hello, First of all, let's start with some simple questions. 1 Was the cartridge ever refilled or is it in the original state? 2 How exactly did this occured? I'm asking this because most printers have a limited space inside them for the cartridge to move around when printing. If they don't fit exactly as they should, they will most likely hit something in their movement when printing. If your cartridge was refilled maybe the person who did that didn't attached the cartridge top part properly and now it moved out of position and hits the inner top of the cartridge housing. Please provide me first with these informations so I can better assist you.
Sep 09, 2007 | Lexmark Color JetPrinter Z52 InkJet
Lexmark Z52 printer does not show ink level
The pdfs you quote apply to Windows 95 and Windows NT. What Windows version are you running? You need the appropriate pdf for that version.
Jun 27, 2009 | Lexmark Color JetPrinter Z52 InkJet
The ink carrier has a clear carrier jam message...
  6. If the problem persists, then its a hardware issue and you should contact Lexmark for replacement of the printer.
Apr 08, 2009 | Lexmark X5470 All-In-One InkJet Printer
Carrier Stall is the error
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X1150
"Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 null.gif null.gif null.gif
Nov 16, 2007 | Lexmark X1150 All-In-One InkJet Printer
Ink Cartidge reset
I ahve the same problem can anyone help it keeps slamming !!!!!
Nov 07, 2007 | Lexmark X83 All-In-One InkJet Printer
Printhead
Oct 26, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark Color JetPrinter Z52 InkJet Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
