Function overloading souce of function overloading using c++
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
C++ function overloading is well heres an example
cout << " string here" << variable << "end of string " << endl;
its a feature c++ allows to make everything easier :)
Posted on Oct 05, 2012
  • 537 Answers
Wow...this one doesn't have anything to do with servers really.
I would pick up a good c++ book that discusses overloading. This is a simple C++ concept.
For now, look at something like:
http://www.codersource.net/cpp_tutorial_function_overloading.html
Hope this helps.
Mike
Posted on Mar 19, 2008
Screen start up and display normal for few seconds and turn black but tv'filament still on.
good... power souce and tv filament is ok
front panel bottom not function.
this is a real problem to fix
causes
faulty printed board / dry solder even a diode or chip fault
May 12, 2016 | Televison & Video
2007 Tundra 4.7 limited... When I started it today the check eng light, traction control light and the 4wd lo light were all lit up and blinking the vehicle would not accelerate (sp).
Blinking your now in limp mode Your looking at the APP for the souce of fault. Once the APP has detected a fault your VDIM( vehicle Dynamics Intergrated Management system controls function such as ABS, w/EBD,BA,ECB,HAC,TRAC and VSC this allow operation together. ) gets disabled. Have the APP sensor troubleshooted. it is part of throttle pedal assembly and is not serviceable.
Apr 23, 2011 | 2007 Toyota Tundra
Have picture - no sound?
Hello
Surf through its menu, come to sound settings and look if "Mute" function is set to "ON' or not. If mute function is set to "ON" there will be no sound at all. If it is set to "OFF' it is OK and connect the TVs audio output socket to any known audio souce like amplifier or other. If sound doesn't come from it also, it means that the audio decoder section circuit inside your TV is faulty and should be replaced. If there is sound from the external amp; check the speaker and audio output IC OK.
Mar 24, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Tuner Keeps Turning Off when a Loud Noise is Played
It's a receiver, not a tuner.
Clearly something is overloading it or forcing it into self protection.
What else is drawing power from the same souce as the receiver, or from its convenience outlet. There IS a limit to how much current it will support.
Try checking the speaker connections and their impedance to make sure it's not unacceptably low.
Apr 02, 2010 | Audio Players & Recorders
Kenmore 84042 electric dryer we use these in our assisted living community and staff say it takes forever for cloths to dry vents ok and blowing heating element heats up but was wondering if heating...
heatibg elements cycle on and off at regular intervals,due to thermostats that regulate the dryer temp. for functional and safety reasons.if your dryer is a residential unit being used in a commercial setting,chances are its being overloaded...a dryers most basic functions are: 1.heat 2.turn and 3. evacuate moisture. its either overloaded or a venting problem-nothing else
Mar 10, 2010 | Kenmore 84042 Dryer
After making a movie, how do I edit it? ajoe968@verizon.net
if you have a pc you can use windows movie maker, or dowload wax (open-souce) at www.debugmode.com/wax/ or if you have a mac use imovie or wax
Oct 21, 2009 | Cameras
Pioneer DEH-3850MP - can't change or set the time
On Pioneers, you usualy have to set the time with the stereo off. If you push and hold the souce button for a few seconds, it will power off. Then push and hold the function, or audio button for a few seconds, and it should go to the menu you need to set the clock. Hope this helps.
Aug 17, 2009 | Car Audio & Video
York screw chiller R-22
hi! there;
there are several causes we can consider in tripping of unit on auxillary sensor.the sensor device was designed to cut off source at specific limit of time or load.the over load sensor device was equipted to the main source specially on cmpressor of chiller to protect of burning the motor.
common causes of tripping off unit
1.high current on supply source.you can check this on one common line of compressor.using clamp ammeter.what ever reading you got when unit is running,compare this on rated current on manuals if high ampere was registered.ther is an overload supply the over load sensor will activate and cut off your unit.
a. source of overload is due to obstruction on refrigeration system,filter dryer are clogged,excessi9ve oil on high side.
b. themostat not cycles on,due to poor condensing fan, dirty condenser fin tube,or condeser insufficient cooling effect.
c. bearing,lubrication are not maintained usually on compressor on open type unit,
2. electrical wire and electronic control board short circuited.
a.sometime relay malfunction on cantactor w/c the supply souce intermittent either on one line supplying compressor,the compressor will suffer,it will just hum and trip off,
b.busted capacitor will trip off your unit,due to in the absence of starting motor.
this are common ways unit trip off, so regards and have a nice day,and one thing more don't forget to rate me, thank's
Apr 08, 2009 | Heating & Cooling
Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Dec 24, 2008 | Audio Players & Recorders
AMPLIFIER CENTER CHANNEL NOT FUNCTIONING
Center channel will not work unless unit is set for Surround or Pro Logic. Make sure center channel's volume is up
Apr 28, 2008 | Yamaha DSP-A3090 7-Channel Amplifier
Computers & Internet Logo
70 people viewed this question
Alun Cox
David Payne
David Payne
