Question about Miele W526 Front Load Washer
The check inlet light flashes. I have cleaned the
I have a miele w 526 washing machine
the check inlet light flashes. I have cleaned the filters in the water inlet hose but it still continues to flash. Any ideas. Thanking you in anticipation
Gaz
    President:
  • 949 Answers
If your sure the water way is clear, unplug the unit, plug it back in,
and see if the error is gone, if not, place the water lines into the tub and turn on the water to make sure water is coming into unit, if so the problem lies somewhere else.
Re-post if this didn't help, and say you did this but still have the error.
Good luck, hope it helps.
Posted on Feb 05, 2010
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
I bought an older 842 washing machine. It has been sitting for awhile so I cleaned out the filter. At first I did not get the plug back in and water ran out and the inlet fault light came on.
Sounds like either the small filter at the inlet solenoid valve or the solenoid valve itself. Either way you are going to have to get inside the machine to get to the inlet valve.If no water is coming through the soap draw then it can really only be at the valve OR the inlet to the soapdraw is blocked (again - need to take off the top to look) Make sure power is disconnected before you do. The flashing red light after 30 seconds or so is just letting you know that the drum has not reached certain water level in the appropriate amount of time.
Good luck
Aug 28, 2015 | Miele Washing Machines
I have a Miele w828. The wash programme stops and the check inlet indicator light is flashing but the stopcock is on ,the hose is not blocked and the filters are clean. What do I do?
If you have water going in to the machine then it is probably a blocked pressure bag.
If no water is going in to the machine then its probably a faulty inlet valve or blocked inlet filter.
Sep 21, 2014 | Washing Machines
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Miele Novotronic W 844 Washing Machine
Pete,
When I had this problem I went along the entire water inlet route and verified flow. Water flow entering the soap dispenser tray should be very robust & audible; if not, you have a flow restriction or low pressure, flashing red light or not.
I'm stating the obvious because I actually missed some filter elements the first time I tried. Disconnect inlet hose at plastic fitting on chassis and verify your flow there. Then look inside the inlet barb and use a small pair of channel lock or lineman's pliers to grasp the tab on the inverted "basket" and pull it straight out. These filters can be packed full of sand and small gravel inside--they were in my case.
Good luck,
Adam
Aug 03, 2008 | Miele Novotronic W1918A Front Load Washer
Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 24, 2008 | Miele WT945 Front Load Washer / Dryer
Miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
May 07, 2006 | Miele Novotronic Premier 500 Front Load...
Miele W526 Front Load Washer Logo
708 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
