Question about Canon EOS Rebel XSi Digital Camera
When I try to take a picture on my rebel eos 450D, I get a "card write protected" message and I can't take pictures. How do I unprotect it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting the card from writing. The position nearest the contacts unlocks the card. If the switch is already in the proper position, try sliding it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Feb 05, 2010
When i try to delete a picture it says that it is protected
Unprotect the picture first. Press MENU, select the Playback tab (right-pointing triangle), then "Protect images," then press the SET button. Select the image to be unprotected and press SET.
Full details are in the "Protecting images" section of the manual (page 129 in my copy). If you need a manual, you many download a copy (and more) from here.
Jul 21, 2012 | Canon EOS Rebel XSi Digital Camera
Camera. Card's write protect switch is set to lock
i try to write protect my pictures on my camera canon eos rebel t3 after that i cant snap i cant do anything when i press the shutter button then it write cards write protect switch is set to lock please help me
Feb 06, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
I have a canon eos rebel xsi 450D. i loaded the eos digital solutions disk on to my windows xp computer. it seemed to load fine. the memory card manager screen appeared on my computer.then a small EOS...
Not a good idea to post your phone # and e-address on this or any other site.
This question arrived on FixYa.
Problem is the camera firmware isn't compatible with the software possible needs a Canon free update or purchase a card reader and download your pictures stepping around the camera.
The computer will look at this card reader with the memory card installed as an external hard drive or memory device.
Download you pictures and then do a safely eject or eject before removing the memory card, once back in the camera remember to format the memory card this give the camera a nice clean surface to work with again.
Apr 17, 2011 | Canon EOS 450D EOS Rebel XSi Digital...
My card says: card write protected & won't let me take pic's
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Apr 21, 2010 | Canon Rebel XT / EOS 350D Digital Camera
NEW Canon EOS 450D display not working
The memory card must be in it. If you take a picture without the card in it, it will show for a few seconds then go black. There must be a memory card in order to save the pictures.
Apr 12, 2010 | Canon EOS Rebel XSi Digital Camera
Card protected
Use a separate card reader to download your pics. Then, you can format the card in the camera to get it to work properly.
Mar 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Card write protected
Check if the card is truly write protected (check the little slider on the SD card). Its possible it slid into lock position accidentally
Nov 25, 2009 | Canon EOS 450D Digital Camera
Canon 450D shows "card write protected"
You're supposed to format the card in the camera...have you tried that?
Sep 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xsi gets message card write protected with or without sd card
hi, when i turn on my camera the screen says card write protected? and I can't take pictures on my canon xsi
Jul 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
532 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
