Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
67.0MB used,1.79gb free but won't take more files
Have a 2GB drive, properties says 67.0MB used and 1.79GB free, but I cannot put anymore files on it. Get msg "Cannot copy file:The directory or file cannot be created." Seems that I cannot put more than 170 files on the drive... same result on 2 different Flash drives.
  • 92 Answers
I would try and reformat the flash drive using Control Panel/Windows Administrative Tools/Computer Management/Disk Management.
Posted on Feb 05, 2010
Lexar usb 2gb
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
Jul 04, 2012 | Lexar 2GB Multi-Color USB Flash Drive Kit...
I just took so many photos with my Nikon camera . when i join memory card with my computer, it shows it's empty but its properties show that 800 MB has been used and 1.10 GB is free as mine is 2GB. Can...
When you put the card into your camera did you format it? If you didn't format the card the camera might not be saving the photos using the proper file types, hence the computer not recognizing them? Try going into the cameras menu and formatting the card and give it another shot.
Alex
Dec 11, 2010 | PNY 2GB microSD Memory Card
My kingston usb says it has 7 gb free, but when i copy a movie file of 5 gb it says there isn't enough space.
is it a 2GB or a 7GB Kingston USB drive
control panel admistrive tools,computer management disk management right click on your drive select properties click tools you should see two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when resart
hope this helps
Dec 04, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My pen drive is of 2GB i dont know how but now it showing 1.50GB as used space and only 500mb odd free space and its completely empty,there is no data inside plz solve my problem
Insert the USB stick in your computer, then go to "Start" then "My Computer", locate the USB icon and right click and select "Properties". From there you can do a format of the stick. This will erase all the data including some hidden files that you might have and solve the problem.
Note that even though it says 2Gb, the data you can use is slightly less. This is true for any storage device out there.
Nov 10, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I bought a 2gb to store my photos it coplied
Found these two solutions online, that worked for others. Hope it helps:
BEFORE YOU DO EITHER OF THESE: Copy all the data on the microSD card to a reliable media.
==========Solution #1==============
First manually create a folder on the microSD drive. Move files/folders from the root into this folder.
Apparently you can only have a limited number of files in the root directory of this and similar solid state memory devices, including SD cards, USB Flash drives, etc.
==========Solution #2==============
Some suggest that if the drive is formatted with the NTFS file system that you should reformat the drive to the FAT32 file system. I would do this only if Solution #1 does not work or the problem reoccurs.
(1) Open Windows Explorer, right click the drive and select Format from the menu.
(2) In the Format dialog, select the drop down menu in 'File System' and select the FAT32 option.
(3) Click the [Start] button.
(4) Exit the format dialog once complete.
(5) Restore your documents
Jun 09, 2009 | PNY 2GB microSD Memory Card
PNY 2GB SD Card will only hold approx. 350 photos
Depends on the size of each file ( picture). If your shooting a large formate then it could ( that's all you can get on it.
Jun 02, 2017 | PNY 2GB microSD Memory Card
Toshiba 2GB USB Flash Drive Capacity Problem
format the Flash Drive in in slow mode
click on the properties of flash drive
then click on tools then CLICK ON DEFRAGMENT NOW TAB
Mar 11, 2008 | Computers & Internet
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
133 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
