Question about Cakewalk Sonar 5 Producer Edition Full Version for PC
Choppy recording when i record something it plays back but its choppy just on the playback though.
  • 163 Answers
This could be to do with the format your using to playback.
Hope this helps!
Posted on Feb 05, 2010
Sharp MD MS 702 shows sound is being recorded but on playback shows blank disc, what could be the problem?
That does not sound good. Being optimistic, though, what happens if you record something and then finalize it? Will it play then?
Will it play a previously recorded MD?
Feb 09, 2013 | Sharp MD-MS702 Personal MiniDisc Player
Sony DCR-TRV510 Playback Blank or Choppy
I recently had similar problem. Sony Phone tech support was very helpful. The answers were strange. You need to make sure the cameral is turned off, unpluged and take the battery out for at least 5 minutes. (something to do with reseting firmware). That sort of worked when coupled with there last comment which was to RECORD about 15 seconds and play it back. Mine was instantly healed!
Jan 13, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Help! My Voice recorder is stuck in Slow playback/record
To switch back to normal press the PLAY button during
playback.
"Every time the PLAY button is pressed, the playback speed will switch."
Mar 31, 2008 | Olympus DS-40 Digital Voice Recorder
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
Playback is choppy
I had this problem very recently. In fact I borrowed camcorders from my friends too and after short periods, they too started having the same problem. Essentially, it looks like there is some choppiness every second or so - like there is noise in the audio and video. After a lot of looking around, I finally found a suggestion posted that ACTUALLY WORKED on all 3 camcorders:
I placed an empty tape in the camcorder and recorded a few seconds into it. Then I removed that tape and tried to play the previous tapes that were showing the choppiness. No problems any more. Everything works fine.
What I still do not understand is why 3 camcorders (all DCR-TRV103s) all showed the same problem (with different tapes by the way). And since I still have lots of tapes to copy, I need to know why this problem is happening so I can minimize its occurrence while I complete the copying process.
People have suggested that my tapes are old and may be offering resistance to the camcorder. So I have ordered a rewinder to spin the tapes a bit before trying again. The two possibilities suggested around this was (1) some mechanical switching took place which got reset when recording; and (2) something got corrupted in the software that manages the playback buffer and that software was rebooted when it went to recording mode.
So while this will hopefully answer your question, I'm also looking for explanations for why this happened to me on 3 different camcorders.
Oct 05, 2007 | Sony Handycam DCR-TRV260 Digital Camcorder
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Playback issues
try to forward a blank tape for cleaning until the head has being clean...repeat the procedure 5 times...if nothing happen may be the video head is weak already.....or need to align the camera
Jul 06, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Cakewalk Sonar 5 Producer Edition Full Version for PC Logo
143 people viewed this question
Top Cakewalk Computers & Internet Experts
Dan Shibata
Dan Shibata
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
