Question about Brother MFC-685cw InkJet Printer
The CYan head doesn't fully operate Brother MFC 685
The cyan head doesn't fully operate. The other colors work erll. Brother says it is because I do not use their inks. I think it is because I don't print much in color. How do you acess and clean the dried up ink in the print head?
  • 677 Answers
You will not be able to print correctly, until you install New Brother Genuine Cartridges.
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's and Brother's Printers, I found out that BOTH dp not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 06, 2010
    President:
  • Brother Master
  • 990 Answers
Hello sir; Try to put this cartridge inside the warm water for 5 to 10 minutes and put it back to the machine, sometime it work, sometime not, just try it out.
Posted on Feb 05, 2010
Won't print cyan color
try reseating the magenta ink cartridge or replacing it.
Jan 21, 2013 | Brother MFC 420CN All-In-One InkJet...
Printer will acknowledge only 3 of 4 new ink cartridges - keeps saying change LC51M
doesn't LC51M refer to Magenta(red) not Cyan(blue). on my J435W the colors goes as follows: BK Y C M LC71 Series cartridges. Maybe you have them switched around? just a thought.
Sep 17, 2012 | Brother MFC-5460CN InkJet Printer
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
Cyan ink worked until needed to replace that empty cartridge. Now, all colors print but Cyan. I have cleaned inks, blocked eye with tape, cleaned where cartridge goes with warm water (in those holes),...
First do not use cartrigde compatible or refill because you clogged the print head,is verry sensitive.If you try to clean the print head and nothing you need to replace the print head is the only solution,after replace the print head you print all the colors.
NOTE!!! After you replace the print head use only original cartridge brother !!!!
Apr 07, 2011 | Brother MFC-230c Printer
What does cyan mean on a brother 240-c all in 1 printer it says replace cyan it wont do nothing
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
What is cyan ink
It must be referring to the cyan color cartridge.
"Cyan" refers to the blue-green color cartridge.
Most printers have either 2 cartridges (black and multicolor), or 4 cartridges( black, magenta, yellow, and cyan).
See here:
http://en.wikipedia.org/wiki/Cyan
Hope this helps.
Jan 13, 2010 | Brother MFC-5440CN All-In-One InkJet...
Cyan ink won't print on Brother MFC-665
talked to Brother, cost to much to fix, replaced the printer.
Dec 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother 5440
Make sure the cyan color is pushed down all the way and make sure to run the cleaning and other test prints
Aug 23, 2008 | Brother MFC-5440CN All-In-One InkJet...
How to install
cyan is one of the four colors(CYMK), so maybe you are working with corrupted drivers?
get new drivers for your Brother(who ain't heavy after all)
Mar 23, 2008 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-685cw InkJet Printer Logo
215 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
