Question about Car Audio & Video
I hane a 1996 pontiac bonneville that I just
I have a 1996 pontiac bonneville that I just replaced the battery in and now I am told I need a code to get it to work again Does anyone know the code?
  • 24 Answers
My blazer the code was the key pad unlock lock unlock lock unlock. in any order
Posted on Feb 06, 2010
2001 Pontiac Bonneville sle.starts up on first start of the day. Then after driving I go to start again and it starts then stalls in a few seconds after turning key..I replaced erg valve and maf sensor(...
Get a code reader and then a Hanes manual . It could be various things but I'm thinking fuel injectors or plugs and or wires . But code it and it will tell you
Feb 19, 2015 | Pontiac Cars & Trucks
1997 pontiac bonneville ssei got a O2 sensor bad code, replaced the sensor and still get the same code
when all else fails go to a pep boys or Firestone, let them check it. You cant by - pass good service and new tools. Advance Auto Parts has the handheld device
Jun 08, 2017 | 1997 Pontiac Bonneville
Can't get my blower motor out of my 1996 Bonneville
You will need to remove the engine's valve cover at the rear of engine to remove the blower motor, also replace the blower motor resistor while you are in there.
Oct 30, 2012 | 1996 Pontiac Bonneville SE CA Value
After running my 1996 pontiac bonneville for about 30 mins the car begins to **** and the idle gauge jumps. I was told it was the cadiylitic converter but the normal mechanic i use said that its not...
Check your plugs, black and sooty is too rich, glazed and grey is too lean. If OK then the feedback from the cat is OK too. Do a voltage check on the crank shaft sensor, if open circuit then change it. Check voltage when cold and every three minutes while engine is warming up. If the voltage begins to drop then the sensor is near dead so change it.
Jun 12, 2011 | 1996 Pontiac Bonneville SE CA Value
1996 bonneville keeps missing what about MAP sensor ? MAS replaced Plugs replaced throotle posistion sensor also
have you isolated what cylinder is causing the misfire . You need to check the coils for proper spark at each plug. If you have spark then you will need to check each injector for proper fuel. you can do this by unplugging each injector one at a time to try to isolate which cylinder the missfire is on
or you can have your local parts store scan the car and tell you what code is stored . Most misfire with cause a service engine soon light to come on if the light is on then there is a code store .
Mar 06, 2011 | 1996 Pontiac Bonneville SE CA Value
Will a 1997 pontiac bonneville transmission work
THAT CAN BE THE CASE, THE GEAR RATIO CAN BE DIFFERENT, JUST AS THE REAR WHEEL DRIVE CARS, AND YOU NEED TO BE CAREFUL. THE ELETRICAL CAN BE DIFFERENT ALSO, GET THE SAMME YEAR, MOTOR SIZE.
Feb 15, 2010 | 1999 Pontiac Bonneville
1996 pontiac bonneville wont start has no headlights but does have interior lights. had starter tested was told it was fine. battery is also fine. makes a clunk when i try to start it then nothing. have...
see if you can turn the motor with a ratchet or breaker bar and socket, if you cannot turn it relatively easy you may have a locked up engine, if you can turn it then replace the starter anyway, bench testing is not an accurate way of telling what a component will do when installed in the vehicle. the louder the "clunk" the higher the likelyhood of the locked up motor
Nov 24, 2009 | 1996 Pontiac Bonneville SE CA Value
1996 pontiac bonneville wont start and headlights wont work
If you don`t have any lights on in the instrument panel then try getting a jump start.If it starts then have your battery and charging system checked.If you do have lights in the I.P.then make sure your getting power to the starter.Good luck.
Pontiac bonneville 1996 3.8 l a/c.
Below is the diagram you requested. Please return to rate this solution. Thank you very much.
Greg
Sep 03, 2009 | 1984 Pontiac Bonneville
NY 1996 Pontiac Bonneville SSEi diagnostic trouble codes P0301 and P1441
Since it is a 1996, you probably have high miles on it.
Most cars after 100,000 miles or so are automatically set to have the check engine light come on.
Check these sites click here and here
May 27, 2008 | 1996 Pontiac Bonneville SE CA Value
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
