Question about KitchenAid KP50PS Professional 5 Series Stand Mixer
I have a problem with my kitchenaid. i need a piece that goes into the machine that makes the pieces to mix move. where can i find that piece!!!
    Sergeant:
  • 259 Answers
Not sure which part you mean, but check out this web site for parts...
http://www.kitchenaid.com/flash.cmd?/#/category/262
Posted on Feb 05, 2010
The planetary housing of my Kitchen Artisan mixer moves up and down. I can move in with my hand and it moves up and down occasionally when mixing. This just started.
Properly having a look to find the cause is going to involve removing the planetary (remove chrome drip ring and knock out the pin) and then removing the back cover. Remove the white and the black wires from the speed control and take the return spring off the bottom of it. Undo the 9 screws holding the gear cases together and separate the 2 halves. You will now be able to inspect the shaft, spacing washer pins and gears on the planetary driving shaft. Normally they have a bit if movement up and down in the planetary (when it is fully assembled) I've never found a fault within the gearbox to cause it or if I have it's been through someone pulling it apart and not assembling it correctly. When I do them I add an extra fibre washer on the outside between the planetary and gearbox housing, there should already be one there, I add another of suitable thickness to remove play but not make it tight.
Dec 18, 2016 | KitchenAid Food Mixers
How do I identify and order the part I need fixed on my Kitchenaid K5?
It is called the Bowl support. It is part #4 on the diagram in the. Instruction manual.. I
Aug 09, 2014 | KitchenAid 5KSM5BER K5 Heavy Duty Mixer...
Why will my kitchenaid stand mixer only go fast?
You will need to look under the back cover and make sure that the lever is moving the speed control plate out and in at the bottom. Out = fast. If that is moving freely and there are no broken pieces inside that back cover (springs, brass governor bits) then replacing the small pcb at the top with the 4 wires coming out of it should solve the problem.
May 21, 2014 | KitchenAid Food Mixers
Mixer head is loose beater scrapes bottom of bowl makes loud thumping noise
I assume you mean that the top half of the mixer, above the pivot pin, moves with respect to the lower half of the mixer, the stand part. There is a pin on which the top half pivots which becomes loose.
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Apr 10, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
I have a KitchenAid Artisan stand mixer (325 watts/model KSM150), about 5 years old. Lately, when mixing dough for bread or cookies, the motor head of the machine wobbles a bit from side to side. In...
the solution to this is to tighten the screw visible through the base that intersects the pin. Turn the machine upside down and using a long flat screwdriver tighten the screw.
Feb 20, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Pin on that holds the mixer on the stand came out and I can't get it to go through the hole
Use this as a reference.....
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
Aug 17, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid 5 Plus KV25GOXER in France
Bonjour fayollec. Try kitchenaid.com for ordering parts. You can download a parts catalog for your mixer from this site. If no parts there, try whirlpool.com. Whirlpool owns Kitchenaid.
mendingshed.com has Kitchenaid parts also.
Bon Chance! ricardok45
Apr 21, 2009 | KitchenAid Food Mixers
Humming kitchenaid
Hi. You have internal damage to the transmission caused by the jamming of the beater. Go to mendingshed.com and download their free Kitchenaid Repair Manual. This covers your K45SS Model. Go to kitchenaid.com , click on customer care, then select search for manuals. Enter your k45ss in this manner k45sswh. Download the parts list. You are now "Armed and Dangerous"!
Unplug the mixer! Follow the instructions in the manual for disassembly. This Manual is worth it's weight in gold.
Get yourself lots of paper toweling and a pair of disposable gloves. This is a greasy project. The trick is to clean off each successive piece removed from the trans, inspect it for damage, and lay each piece in sequence on a piece of cardboard to make reassembly easier, or take a digital photo of every piece as you remove it. Modern technology makes so many repairs now possible due to the immediate photo documentation we can get. Priceless!
Finally, I recommend replacement grease, Chevron FM ALC EP-2 Food Grade grease. Non-toxic!
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 17, 2009 | KitchenAid K45SS Classic Stand Mixer
Pops out of lock under a heavy load
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto www.consumeraffairs.com and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
Mar 08, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Stopped Mixing While Kneading Bread
Hi again Libby. You're right to be scared about further damage. If you want to fix this machine yourself, stop using the mixer. Go to the Kitchenaid website and download the drawings that match your mixer model Unplug the mixer! Take a screwdriver and remove the silver band from around the head of the unit ( 1 screw). Next remove the four screws that hold the top part of the mixer. Remove that cover, and look for a 'humpy" looking cover at the front of the machine. Examine this transmission cover carefully. If the cover is made of plastic, look for cracks. If you don't find cracks, you'be better off taking it to a repair shop. If you do find cracks in the plastic cover, remove the four screws that secure it. Remove the trans. cover.
You will now see a lot of grease in this exposed transmission. Put on some latex gloves, get a bunch of paper towels and move some of this grease aside so you can lift the worm gear assembly free of the mixer ( see Kitchenaid drawing). Wipe it off and look for damage to the worm (spiral) gear. Look for damage on the other gear of this assembly, inspect the 2 bronze bearings at either end of the shaft. You're looking for cracks in, or pieces missing from the bearings, look for damaged teeth on the gear. Should you find damage at any stage, that part must be replaced. These parts can be ordered from the Kitchenaid website, and will take about a month for them to arrive.
When you order the required parts, insist that the replacement trans. cover be made of metal. When my mixer "blew up", my replacement was a metal one. If your problem dosen't fit the above solution. I can't help you further. If it does, please rate my solution.
Depending how much grease you had to take out to do the inspection, you might have to order a container of grease to replace it. Good luck! ricardok45.
Jan 23, 2009 | KitchenAid KP26M1X Stand Mixer
KitchenAid KP50PS Professional 5 Series Stand Mixer Logo
65 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
