Question about Toshiba Satellite 2775XDVD Notebook
I can't get it to display anything but large icons and 800x640 display. It is way too large displaying anything.I have tried looking for a newer driver to no avail foe the multi media display.
    Genius:
  • 1,189 Answers
  • Hi, you can try this; in a clear area of the Desktop screen (right)) click, once the desktop windowI can't get it to display anything but large icons - 2_bing.gif open, click on Personalize, next click on Display Settings. You can adjust the brightness by doing the following: On the "resolution scale" adjust from (Low>High) you can do this until you are satisfied with the view. In the ("Colors drop box"), select the down (Arrow), and choose the "Highest" color (16bits>32bits) etc. Next click to open the (Advance settings), select the ("List All Modes") button, once the window open choose the (Highest) settings: example (1366 by 768, True Color (32bit), 60 Hertz. Remember to click the "Apply", and "OK" buttons after each selection, and changes. "Restart the computer, to finalize the application." "Did this solution help?"
    Feedback: "Helpful Ratings" appreciated! thank paul7of9
Posted on Feb 06, 2010
  • 644 Answers
Goto my computer and right click, go to properties, device manager, in there click on the + sign on display adapters, right click on the one it brings up and choose to update driver, use the internet option to search for the driver, be patient it a few minutes.
Also have you gone to the screen properties check that the settings in there are set to 32bit.
Posted on Feb 05, 2010
Start up screen has strange large icons and lettering
Are you in "SAFE MODE"? if not it only a display setting, it can be changed.
Oct 30, 2012 | Lenovo Computers & Internet
Program too large to fit screen hp mini 110 notebook
Change your screen resolution on the Display in the Control Panel.
Click Start/Control Panel and look for Display or Appearance and Personalization (depending on your operating system). When the Display opens increase the Screen Resolution. The resolution will be under the Settings Tab on the Display. The higher the resolution, the smaller the icons and things will be on the screen, therefore you'll see more.
Apr 19, 2012 | Computers & Internet
How to change icon size on laprop
Try to go to this link, on how you change icon size.
http://www.techtalkz.com/windows-7/516049-how-change-font-size-icon-size-windows-7-a.html
AnEspera
Apr 18, 2011 | Computers & Internet
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Installation of aoc monitor
hmmm ok your resolution is probably set to high for that monitor you should start at 800x640 and go up from there you will probably have to borrow a newer monitor and set it lower
Oct 29, 2009 | AOC Monitor
Large monitor has distorted display
try adjusting your system resolution to a largest one (as 1280 x 800), or using a DVI cable, if your monitor and video card supports it.
Jul 12, 2009 | Acer Computers & Internet
Hannspree 19" HF199H LCD - Display is LARGE on monitor!
Try Control Panel - Appearance or Display- You can change how your 2nd display looks there.. Sounds like you have it set in Clone mode...(both displays show the same things)...See if you can reset the 2nd display resolution while keeping the laptop in its normal resolution. Not all machines can do this...but most recent ones should be able to.
Mar 27, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Toshiba Satellite 2775XDVD Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
