Question about Kenmore Refrigerators
Refrig will not syay cold Only 6 months old
Refrig will not stay cold. Only 6 months old. Have thermostat in freezer. Temperature will not go below 38Degrees. Bottom section cool but not cold enough. Both thermostats are set to maximum Model 253617240C, Model type As-17
    President:
  • 1,218 Answers
Good day,
Not your problem. The machine carries a full one year warranty on all parts.
Call Sears for a warranty service call.
Posted on Feb 05, 2010
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
No Temperature in Refrig
It indicates that there is problem with your thermostat .
How old is your refrigerator ?
Are you facing this problem frequently ?
SAM ANDERSON
Sep 30, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Refrig part got up to 68 degrees inside. Freezer still stayed cold. Why would this happen?
1. Check the setting on the frig. 2. Thermostat on frig may be broken and frig goes to near room temperature.
Sep 01, 2011 | Refrigerators
My fridge is about 6yrs old, and it just stopped getting cold, it runs but just not get cold. The fridge and freezer does not get cold. help!!
You should have it serviced at least once a year. Any way since it is 6 yrs old please get the cooling gas checked up. Quite possible that cooling gas has leaked out over a period of time.Also get the thermostat switch checked. It may be also not functioning properly. Check the settings of the thermostat. It should be set on the cooling side.
Oct 04, 2010 | GE Refrigerators
Fridge is warm with no cold air.
Unless there are 2 thermostats, one for freezer and one for refrig, it's not the thermostat if the freezer is ok. Sounds like the small fan that blows the cold air from freezer into refrig is not operating.
Jul 23, 2010 | Refrigerators
Can't change temperature
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
May 24, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
My maytag refrig. is 3 years old. model #747908 HS520AS. freezer on bottom-refrig on top. the refrig part is not staying cold. have cleaned under frig and vaccumed back and underneath and it still is not...
All the cooling coils for this model are in the freezer section. There is a fan down there behind the back wall on the top. This fan directs air up to the fresh food section.
Check the temperature of the freezer you can do this by inspecting the ice cream, if the ice cream is soft you are above 5 degrees F. If you have a good cold freezer then the problem is with air flow, the evaporator fan that I spoke of could be bad).
If your freezer temperature is not as cold as it should be you may have a defrost problem, look for any signs of frost build up on the back wall of the freezer section, if you see frost you will most likely need to put in a new control.
If the freezer temperature is warmer than normal and you do not have frost you may have a sealed system leak, this will require a technician for sure.
Apr 18, 2010 | Maytag Refrigerators
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator will not stay cold
Bought a second hand fridge that was running well. We layed the fridge on it's side for moving and let it stand upright for at least 4 hours. The moving was only 45 minutes. The freezer is semi-cold but the main body of the fridge stays at aprox. 68 degrees. Any solutions.
Oct 31, 2007 | Refrigerators
Refrigerators Logo
82 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
