Question about Kenwood KVT-715DVD Car DVD Player
Engine rev "noise" coming through
New Subaru RS with in dash dvd sat nav etc. Had a amp and new speakers installed but now get an engine " whine" when the car revs through the sound system.
Installers said I need to get a RCA cable from Subaru to fix the problem, but no one at the dealership knows what I'm asking for.
Is this right? and whats the part called ?
  • 102 Answers
Hi first check the ground wire from the amp. It needs to be to a body bolt that's less then 18" from the amp and is clean no paint ect. raw metal. Also the rca wire to the amp should be ran on the opposite side of the car then the power wires. This should reduce engine noise. They also sell a noise reducer that helps in vehicles that are wired correctly but still have a engine noise.
Posted on Feb 05, 2010
My Kia makes a whining noise upon acceleration- engine seems to be ok at freeway speed
check the condition of the alternater etc drive belts , to test rev engine and spray a little WD 40 onto the belts, if the whining goes then if your lucky a new set of belts will be all you need to change , but it could also mean a bearing is wearing out on one or more of the components that are being driven by the belts ,so more diagnosis would be needed if still whining after new set of drive belts
Mar 23, 2015 | 2005 Kia Sportage
01 ford escape w/ 185,000 miles. warning sound of 5 consecutive dings then pause and a few minutes later, 5 more, and continues to do this at various times and then sometimes it doesnt do it at all. ...
The dinging from the dash is the Air bag system check. Check that the bulb in the dash isn't burned out. The stalling and spitting could be clogged converter. Check how much exhaust is coming out of the tail pipe when you rev it. The smoke could just be from a leaking valve cover gasket.
Aug 02, 2011 | 2001 Ford Escape
Just replaced a dead battery with a brand new one. Tried starting it and it makes a high pitch whining sound and wont start. Any suggestions of what the problem is? Does it need to sit to charge the...
The basics, your battery is used to provide power to the starter. Once the engine is running the alternator then provides current to recharge the battery and run all of your electrical components. so I would suspect the starter is not working to start the engine.
Feb 16, 2011 | Chevrolet Classic Cars & Trucks
I just installed an amp to my stereo and i now have engine whine coming through thestereo speaers it goes louder and higher pitched as engine revs
if you are lookin at your rca's you have the centre pin and on the inside in between the centre pin and the outside of the rca put a bit of wire there and plug it into your deck then connect the other end to an earth
have you got the power wires running down one side and the rca's down the other
or you can goto an electronics store and buy an rca noise suppresser
Aug 13, 2010 | Car Audio & Video
Trying to register a new Garmin sat.nav. So far
Try this link. If you can't just click on it, copy it to your browser line, not a search engine like google.
https://www8.garmin.com/registration/contact_info.jsp?regID=07381817
Aug 28, 2009 | Garmin Nuvi 205T Sat Nav GPS Receiver
Forester 1998 Battery & brake light switch on
Check to see if your Alternator belt is still on.. If it's connected to your power steering it won't work and your battery will not charge. Also if you hear a whining noise in your engine replace the belt if it's there.
Jun 05, 2009 | 1998 Subaru Forester
High pitch noise from engine compartment in 2003 Subaru Fores
There is a little beeper that sits just behind the front grill close to the Subaru emblem. It makes the sound you hear when you press the remote to lock or unlock the doors. It sometimes whines for a while but eventually stops. I have had this for a couple of years and it does not appear to have caused any problems.
Feb 03, 2009 | 2003 Subaru Forester
Loud engine whine (like a jet noise) from 2002 subaru forester
Have you crawled under the vehicle and personally inspected your exhaust line from manifold to tail pipe? The roaring sound usually occur when there is a hole in the exhaust line. I had it happen to my forester before. A hole half the size of a dime made my subaru sound like my old 74 chevy pickup.
Dec 06, 2008 | 2002 Subaru Forester
Can you put factory sat nav in an X5 when it does not already have it in
Hello There
Yes it is possible to install the factory sat nav in you X5, but apart from the head unit you will also need:
  1. new wiring loom
  2. dvd navigation unit installed at the back
  3. TMC radio unit again at the back
  4. bluetooth unit
All the interior needs to come out i.e seats, floor carpets, door trims.
If you feel brave enough then there are BMW forums which gives you very detailed information on how to to it, but don't expect to get it done in a day or even two, a week is probably realistic time. It took me 2 weeks to do my first 3 series.
Hope this helps. Please don't forget to rate me.
Many Thanks
Jul 12, 2008 | 2005 BMW X5
Engine noise from Legacy 4000W 2 channel amp
Hi Justin,
Send me the specs. on the speaker ( voice coil impedance), amp, power wire size, and box
As for engine noise ( alternator whine) 99.9 times out of a hundred it's caused by what's called a ground loop, That will take a little trouble shooting on your part. It's no big deal. It will be a step by step process. All you need is two alligator clips or a old RCA cable.and a couple feet of wire. I'll try to get to it this evening,
Oh, and you will have to pull the head unit out of the dash... P
Jun 11, 2008 | Car Audio & Video
Kenwood KVT-715DVD Car DVD Player Logo
260 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
