Question about Amana Refrigerators
Amana SRD520T - appliance tripped the circuit breaker. After power had been restored the compressor ran but no cooling in freezer or fridge
  • 454 Answers
With the compressor running, open the freezer and listen if the fan is running. If it is not, replace it. Most likely, this is your problem.
If it is running, turn off the refrigerator. Remove the rear panel from the freezer. Inspect the coils. If they are covered in ice, let them thaw completely. This ice will prevent the freezer and consequently, the refrigerator from getting cold.
If the fan works and the freezer coils are not cold, then I am afraid it is time for another refrigerator.
Posted on Feb 06, 2010
Upright freezer trips circuit after moving across room
If compressor is hot, it could be an issue with the starting components. Let it cool down for about an hour an it is room temperature to the touch. If the breaker trips when the compressor attempts to start, I would look at the start components. It may be just a case of unusual timing that they went bad at this time. Make sure there is nothing else on the circuit you have it plugged into. Could be an overloading issue of the circuit.
Aug 04, 2017 | Refrigerators
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
Refrigerator trips circuit breaker
try standing it upside down for a day it will work
May 28, 2010 | Amana ATB2135HR Top Freezer Refrigerator
The refrigerator trips the circuit.
possible failed start /run capacitor for the motorm
call a technician for a proper diagnosis
Oct 06, 2017 | GE Refrigerators
Fridge freezer shorting out electrics
The cause of this situation could simply be an overloaded circuit. Homes are built with dedicated circuit for fridge only now because of this. If you notice power outage in other rooms or other appliances in kitchen then the circuit affected,I.E. other outlets affected need the load lightened. If it is a dedicated circuit then could be faulty breaker or possibly altered wiring could be cause.These have to be ruled out before you will know for sure. If it isn,t dedicated outlet for fridge only, just plugging in a light could overload loaded circuit.
Apr 21, 2009 | Refrigerators
Amana sxd524v fridge-freezer tripped out the power
Hi, you can check if there is a fanmotor on the condenser section and make sure that it is working. Second, you can try replacing the starter relay which you will find in the connection area of the compressor. If this does not work, I am afraid you would have to have the compressor replaced.
Mar 13, 2009 | Amana SXD524VW Side by Side Refrigerator
Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Fridge not working
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician.
Jan 03, 2009 | Amana ABB2224D Bottom Freezer Refrigerator
Amana bottom drawer fridge/freezer combo is only 3 years old. It sounds like it is trying to work but both the fridge and freezer are not working. Not cooling or freezing anymore.
hi. thanks for the question . it sounds like you have a compressor problem . wich is under warranty from amana. great news get in touch with amana thanks the appliance doc
Sep 28, 2008 | Amana Refrigerators
Suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Mar 21, 2008 | Refrigerators
Refrigerators Logo
164 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
